Results 1 to 9 of 9
Thread: Misc Turbo Parts
    Misc Turbo Parts
    I have a bunch of misc turbo parts I would like to move out to make room for more :D Everything OBO, let me know if you would like better pics of anything.
    Aftermarket (Turbonetics) dual port waste actuator with adjustable arm plus laser cut mounting bracket for T4 compressor. Never used, was bolted up to mock up and I'm going a different direction. $80.00
    http://rides.webshots.com/photo/2918...66453426QYnFvI
    http://rides.webshots.com/photo/2142...66453426Dlniob
    http://rides.webshots.com/photo/2509...66453426YCVZig
    http://rides.webshots.com/photo/2605...66453426syAICG
    Aftermarket (Precision) single port waste gate actuator with adjustable arm. This one has a welded bracket set up for a T# compressor housing. This will not work with the 2.3 standard manifold / turbo configuration as is (see third picture), would need modified, or great for custom set up. $50.00
    http://rides.webshots.com/photo/2263...66453426vVFVGU
    http://rides.webshots.com/photo/2095...66453426irumyD
    http://rides.webshots.com/photo/2388...66453426zddLWd
    Stock (Garrett) wastegate actuator for Ford / Garrett T3 turbo. This one still has a good heat shield (usually rotted off). $40.00
    http://rides.webshots.com/photo/2115...66453426WngsHo
    http://rides.webshots.com/photo/2674...66453426FDmdiV
    http://rides.webshots.com/photo/2441...66453426nIBQKQ
    Stock T3 outlet elbow with internal wastegate puck (swing arm). This one has the studs removed for use of through bolts. I change mine to this way so I can drop the exhaust without getting under the car, plus it seals better this way (downpipe not included ;) ) This one was on my car until I installed the ATR big outlet this summer. $30.00
    http://rides.webshots.com/photo/2687...66453426dapKGe
    3" downpipe for 2.3 turbo fox chasis car using stock outlet elbow. This is a Sacremeto Mustang downpipe (no longer made) that was cut off just past the last bend. Use this to start you 3" exhaust just before the tranny crossmember (Turbo elbow not included, but would package these items). $65.00
    http://rides.webshots.com/photo/2889...66453426okpVfa
    http://rides.webshots.com/photo/2810...66453426Lsjfwf
    E6 turbo manifold for 2.3. When removed, two of the studs came out, one nut came off, and one stud broke (although it's long enough to get out with heat). Use this one to port while you are still driving your car :D $40.00
    http://rides.webshots.com/photo/2042...66453426GWSydW
    http://rides.webshots.com/photo/2099...66453426hAJawX
    http://rides.webshots.com/photo/2164...66453426FRYNQe
    IRCM (Intergrated Relat Control Module) and BAP from 87/88 TC. This is the module that houses the EEC relay, both fan relays, and fuel pump relay those TC's. Removed working from my car. $20.00
    http://rides.webshots.com/photo/2330...66453426joCkYK
    http://rides.webshots.com/photo/2057...66453426duJOnj
    http://rides.webshots.com/photo/2345...66453426MGCvOi
    4 cylinder turbo fan from the early fox cars (early TC, SVO, Capri turbo GT turbo, etc) $20.00
    http://rides.webshots.com/photo/2195...66453426wavRas
    I am also going to have some other cool parts for sale soon including 3" ATR downpipe with flex joint, PE EEC (bad ass of the 2.3 turbo computers). both these are still on my car, but coming off soon.
    Bump - get them while they are hot :D
    LowHill
    2,679
    I will take one downpipe and my uncle wants the other, consider them sold.
    Bump - this stuff needs to go, offering local before it goes on eBay.
    Digging through some other stuff.......
    I have a finned turbo outlet pipe for a non intercooled car. This is the pipe that runs from the turbo to throttle body but also has cast in cooling fins. $10.00
    Hurst Tee handle shifter knob with button (for line lock, etc) $30.00
    SVO power steering rack, pump, lines, tie rod ends, etc. It was removed as one piece, never cracked a line. $50.00
    87/88 TC rear sway bar (will work on fox as an upgrade) $10.00
    SVO front sway bar with green bushing end links $30.00 (will not work on normal fox, too wide)
    Make offers on this stuff before it goes to eBay. All needs to go, once it's gone, it's gone.
    Member gtboost02's Avatar
    Dec 2008
    latrobe
    45
    bob, i'll take the t handle if it will fit a stock t-5 shifter rod.also is that t3 wastegate HD? if so i'll take it as well. chuck
    One last bump before i get this stuff gone via other channels ;) I need cash :D
    Bump for stuff that's left. Anyone that wanted stuff get it before it's gone ;)
  1. Misc 94-98 Parts
    By arayray in forum Ford Vehicles
    Last Post: 05-22-2013, 04:06 PM
  2. Few misc Fox parts F/S-F/T
    By BADASSPONY in forum Ford Vehicles
    Last Post: 11-22-2009, 08:39 AM
  3. Misc. Fox parts
    By frankstang in forum Ford Vehicles
    Last Post: 08-31-2009, 06:04 PM
  4. Misc parts for sale
    By PSPstang in forum Ford Vehicles
    Last Post: 01-07-2009, 06:14 PM
  5. misc. parts
    By fast4ord in forum Ford Vehicles
    Last Post: 12-31-2006, 08:37 PM
