Results 1 to 2 of 2
Thread: Teeter Hang Ups Inversion Table
    North Hills of Pittsburgh
    430
    This is a very sturdy inversion table. I've barely used it, so it's in new condition. I paid $375 new, but I'm only asking $200 or best offer. Thanks. Max height of 6'6" and 300 pounds.
    Amazon.com Product Description
    If you're plagued by back pain, stiff joints, or suffer from stress overload, consider the Teeter Hang Ups F5000 inversion table, which helps to counter the effects of too much time spent sitting, standing, or moving repetitively. It's also a great way to add extra crunch to exercises like sit-ups. The F5000 is specially engineered to provide a comfortable and secure inversion experience. The equipment features heat-treated, high quality carbon steel and triple-plated chrome.
    The Teeter Hang Ups F5000 rotates on a pivot system. With simple arm movements (rotation is accomplished by shifting the weight of the arms), the table easily rotates to any comfortable angle. The smooth rotation allows for oscillation and intermittent traction. Adjustable roller hinges allow you to pre-select three levels to control the aggressiveness of rotation, and the tether strap allows you to pre-select the maximum angle of inversion. Comfortable ankle clamps hold you securely while inverting. Additional support can be gained by use of the optional Teeter Hang Ups Gravity Boots.
    It's able to lock at full 90 degrees inversion (this is only possible when using the more aggressive roller hinge setting). While at 90 degrees, you can perform inverted sit-ups and squats. The table is self-controlled and can be unlocked with simple arm movements.
    Feature Detail:
    Removable, washable nylon mat with triple-stitched seams removes easily for cleaning
    Teflon embedded epoxy-coated roller hinges for guaranteed smooth rotation with no squeaks for the life of the table; patented cam locks ensure proper assembly
    Durable, injection-coated rubber hand grips feature an embossed guide to the angles of inversion
    Adjustable tether strap allows you to preset the tether strap for worry-free inversion to any angle
    Heat treated high quality carbon steel used in key structural components for increased strength and durability
    Curved foam ankle clamps offer a unique design that allows for greater comfort and security while inverted
    Self-locking hinges secure the table bed to the A-frame for improved security and portability
    De-rattler knob reduces shaft movement to allow for quiet, shift-free rotation--the only design on the market to structurally engage the main shaft
    Triple-plated chrome main shaft with steel wall thickness at least 20 percent greater than any main shaft on the market. Features embossed height markers in both inches and centimeters for easy adjustment
    Height capacity: 4'8" to 6'6"
    Weight capacity: 300 pounds
    Assembled dimensions: 45 x 28 x 58 inches
    Folded dimensions: 66 x 28 x 14 inches
    The F5000 Inversion Table folds compactly for storage in a closet or in a corner. The nylon mat can be removed for washing.
    2016 GT Premium
    430
    Sold
    Sold
    2016 GT Premium
  1. Guess what the UPS guy brought me!
    Last Post: 11-03-2010, 06:53 AM
  2. Ricer hang outs in/around the 'Burgh
    By EricS197 in forum The Bar
    Last Post: 07-22-2010, 07:46 AM
  3. tips to hang xmas lights
    By J-rod in forum The Bar
    Last Post: 11-28-2007, 11:02 PM
  4. any terminators hang out on Rodi Rd??
    By cobra232 in forum S197
    Last Post: 11-23-2007, 12:06 AM
  5. How many push-ups can you do?
    By Pure Stock in forum The Bar
    Last Post: 02-14-2007, 12:07 PM
