Results 1 to 16 of 16
Thread: 900 CI Mountain Motors!
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    Sonny Leonard & Pat Musi are both building purhrod motors over 930 ci now & 1000 CI is on the horizon. These things have 5" bores, 2.7" intake & 2.00 exhaust valves.
    http://www.competitionplus.com/index...8245&Itemid=24
    Cool stuff!
    Mark Lowry
    Uniontown
    1,792
    Not much to say to that other then....WOW!
    Got Smoke?
    I probably couldn't even afford the valve covers!
    Selinsgrove, PA
    526
    Fox/n.
    ruffsdale
    3,625
    I just ordered one for my golfcart.
    my heros..
    Caledonia, Ontario
    620
    Ad #1323374 Posted:2008-11-04 12:17:09
    This ad expires in 14 days.
    SONNY'S EXTREME PRO STOCK 892c.i. 5.300 b/s
    2100HP NATURALLY ASPIRATED (NO NITROUS)
    $83,000.00
    EXTREME PRO STOCK 892 C.I.
    2008 892 CU. IN. ENGINE WITH SONNY'S DESIGN
    5.300" B.S. GM HEMISPHERICAL CYLINDER HEADS.
    2100 NATURALLY ASPIRATED H.P.@ 8100 RPM 1410 FT. LBS TORQUE @ 6500RPM
    Special Features:
    *--Sonny's 892ci GM Hemispherical headed engine features Ultra Lite CNC program that weighs 2 lbs less than the 784 ci Hemispherical headed engines.
    *--Sonny's 5.300" GM Hemispherical head has a 1.600" longer bore spacing than the 5.000" GM Hemispherical heads
    *--Four Braswell 2bbl carburetors featuring 2.400" throttle bore feed pistons with 16.0:1 static colmpression
    *--The cam has a gross lift of 1.200" with a 1.85 rocker arm ratio with .685 lobe liftl
    *--The 5.300" cylinder head's intake runner has a volume of 652cc while the exhaust is 212cc which flow 660cfm @ 1.100" lift with a 2.725" valve on the intake and 470cfm @ 1.100" lift with a 2.100" valve on the exhaust
    Sonny's in-house fully CNC ported "Next Generation" Hemi cyl. heads
    SAR Special Billet Aluminum 5.300" B.S. block with 1.100" raised cam
    Bryant billet crank
    BME 426 aluminum forged rods
    Venolia pistons
    Jesel keyed lifters
    1.031" tool steel taper-wall pins
    Federal Mogul "Hell Fire" rings
    Special titanium valves & PSI springs
    SAR shaft mounted rocker system with needle bearing roller tips
    Jesel belt drive
    Moroso 4-stage dry sump oiling
    Moroso vacuum system
    ATI balancer
    MSD cranktrigger ignition
    SAR sheetmetal 4x2 intake with linkage
    SAR/BLP (4) 2 barrel split dominator carbs
    Sheetmetal billet rail valve covers
    Meziere hi-flow electric water pump
    Pro series CSI starter
    Fuel lines with 4 port regulator
    SAVE 4,800.00 ONLY 83,000.00 IF ORDERED BY 11/15/08
    CALL TODD @ 509-710-6544
    Seller Phone Number: 509-710-6544
    This item is NEW
    This item is NEW
    Trades NOT ACCEPTED
    Item Location: DEER PARK, WA
    Mark Lowry
    Bunker Hill, Wv.
    672
    Ill take one with 10:1 compression for pump gas
    2010 Gt 5spd....WIFE's car.
    2,145
    I hear they get 38MPG or was that 38GPM?
    Stock 03 Cobra Vroom Vroom!!
    892 cubes that peaks at 8100rpm....LOL
    2.35hp/ci....
    Ligonier, PA
    6,365
    One of those in a lambo would be sweet
    2018 Jeep Grand Cherokee
    1931 Ford Model A - Project
    1991 BMW 325iX
    1978 Ford F150
    1952 Ford F2 - Project
    Oct 2007
    Baldwin
    259
    2.35hp/ci....
    I wonder how often you have to rebuild the thing.
    2012 Husqvarna TE 449
    2007 BMW E92 328xi
    2003 F250 Superduty
    2004 SV650
    Bunker Hill, Wv.
    672
    If you can afford 85k for a longblock...you arent worried about 2k for a rebuild a couple times a year lol
    2.35hp/ci....
    That dont impress me much ;) 140 cu/in x 2.35 hp/cu = 329 HP, I got that covered
    Seriously, those are insane engines. There was a nice write up on them in Drag Illistrated a while ago. As I understood it, they are supposed to be pretty robust too.
    Looking at the new edition of DI they have some "used" but freshened one on SALE!!!!!!!!
    811 cu/in - 1800 NA HP $69,600.00 Ran 6.60's and low 6.70's @210 mph in a 2375 car. Expected to run 6.20/6.30 in a 1900# dragster.
    832 cu/in - For some reason this one "only" made 1810 HP in NA form, this one is a good deal at $63,000.00 only 12 runs and freshened.
    Brodix is also now making a 5.00 bore spacing block.
    These seem to make the Shafiroff 600" stuff look real cheap at $25K (1225 HP). They do sell 700" / 1900 HP engines but they are on spray.
    Steve Schmidt is also running a special on 737" / 2000 HP combo for $59,500.00 and you can take $1,000/00 off if you order now :D
    It's stupid rediculous the power you can have delivered by truck these days.
    2,145
    It would be sweet until you rev it up and the car flips over. lol
    Junior Member
    Jan 2009
    4
    The guy that owns that 892 incher for sale on rj's name is todd hoerner.... who piloted his 06 GTO ex-pro stocker to a 6.30 pass with a 1.76 low gear P/G!! @ 3000' DA with that motor NA
  1. Ebay Motors format
    By gpfarrell in forum The Bar
    Last Post: 10-21-2013, 09:37 PM
  2. GM = China Motors
    By PaxtonShelby in forum Pictures & Videos
    Last Post: 07-30-2012, 02:09 PM
  3. 02 kx 85 900 $
    By bigmack in forum For Sale
    Last Post: 06-22-2012, 04:42 PM
  4. Who Deals In Building Motors??
    By billyNOTnice in forum General Tech
    Last Post: 11-04-2009, 12:56 PM
  5. Remanufactured Terminator Motors
    By Wolfpack Speed in forum SN95-New Edge
    Last Post: 08-11-2007, 02:32 AM
