Results 1 to 5 of 5
Thread: 93 94
    NEWB svtroush's Avatar
    plum
    110
    93 94
    well they all ready took out most of the 94 out of the pumps. my car has only had 94 put in it all its life. i talked with a guy and he said the 93 was just as good as the 94 if not better.so the car is put away 4 the winter and i was curious to see if anyone else put the 93 in there car yet if there was a diffrance in the 2 gases. if so what am i going 2 do. thanks guys.
    I have been buying Torco Accelerator by the 5 gallon can, and add a quart to each tank. Mine would ping at anything over 21 psi even on 94, so I got into the habit of using it since i REALLY like 25 psi :D. With 1 quart to 16 gallons of 94 I was fine, I only ran a few tanks of the 93 in there and was adding a little more than a quart. Might be worthwhile to add something like a pint to a tankfull if you are concerned.
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    Torco Accelerator
    Bob,
    what's a 5 gallon can of this stuff cost?
    Mark Lowry
    $148.60 for the 5 Gallons, $176.89 total shipped via UPS to my door. It works out to $8.85 per quart in bulk (versus like $16 per the quart).
    The mixing ratios are........
    1 Quart to 20 Gallons of 93 = 97 Octane
    1 Quart to 10 Gallons of 93 = 104 Octane
    1 Quart to 5 Gallons of 93 = 107 Octane
    My Capri has a 16 Gallon tank so adding a quart I figure i'm around 100 octane for the price of less than 2 gallons of race gas. If i'm going to try something stupid with boost or timing, I will add a quart and a half to get up above 100.
    I wish someone around here was a Torco distributor as we could save on the UPS shipping cost as they would likely get it (and racegas) by the truckload. At one time the Tedesco's were saying they were set up as a distributor, but I geuss it never panned out.
    plum
    110
    thanks bob i will look into that i guess when i bring the car out i will try the 93 and see what happens
