Results 1 to 3 of 3
Thread: T5 Seal and Bearing Questions
    Cheap SOB
    Baltimore, Maryland 21236
    288
    I have a new project and have a couple of T5 questions. I have picked up a 1995 Cobra. So the T5 should have that special tapered input shaft bearing. The rear oil seal on the T5 (along with the engine's rear main seal) was leaking. I pulled the seal to replace it. But I don't remember how the yoke sleeve comes out of the tail section. I have the new yoke, bushing/sleeve, oil seal and u-joints.
    So, how does the yoke sleeve come out?
    Since the T5 is currently on the bench, should I replace the input shaft bearing? If so, is it a simple R&R or does it get shimmed?
    Petersburg,PA. 16669
    816
    to take the bushing out you have to take the back of the case of and knock it out
    88 GT...and some boost
    There is no need to change the input shaft bearing. You do however need to dismantle the tail housing to get the bushing out. Its not hard to do. Drive the roll pin in on the shifter cup until the cup moves freely. Take out the housing bolts. Its right there. Be sure to clean everything and use a good sealer to re seal the housing. The 5th gear oiler is a bitch to get back right so be carefull. Itlikes to move around when outting everything back together. Use grease.
  1. Pilot bearing problems..
    By Josh00 GT in forum General Tech
    Last Post: 07-23-2010, 09:07 PM
  2. rear main seal questions???
    By White5.0 in forum Fox-SN95
    Last Post: 06-18-2010, 01:14 PM
  3. Bad throwout bearing?
    Last Post: 12-06-2007, 09:46 PM
  4. need help with 8.8 carrier bearing problem
    Last Post: 06-29-2007, 01:06 AM
  5. fundamentals of measuring bearing clearances
    By George C in forum General Tech
    Last Post: 11-11-2006, 01:21 PM
