Results 1 to 7 of 7
Thread: 1993 mustang lx hatch*modded
    NEWB
    altoona,p.a
    299
    1993 mustang lx hatch "black" 130k on chassis 40k motor
    5.0, 5 spd
    pw/pl/r.def etc also has full interior and the windows were just tinted 10%
    shortblock was rebuilt from previous owner...
    transmision was completely redone last year
    body is very good, some normal scratches,dings etc, the paint is respectable, some area's are better then others...cleans and shines nice though if you stay on top of it. underside of this car is perfect as i have seen them..interior is grey/black and is in great shape for a almost 16yr old car..
    mildly ported tfs heads
    holley 2 intake
    holley 1 inch intake spacer
    70mm bbk tb
    75mm pro m meter
    crane pushrods(hardened)
    comp cams pro magnum 1.6 rr's
    stage 1 tfs cam
    bbk cold air intake
    24lb injectors
    aeromotive fuel press reg
    march alternator bracket kit with pulley's
    powermaster 140 amp 1 wire alt
    csi electric water pump
    ford racing lifters
    egr delete spacer
    ford racing 3 core aluminum radiator
    electric fan
    cervini 1 1/2 cowl hood
    recaro race seats,(fully functional)
    hurst shifter
    t5z trans
    king cobra hd clutch kit
    upr extreme hd clucth cable.quadrant,firewall adjuster kit
    ford racing aluminum driveshaft
    maximum motorsport caster camber plates
    maximum motorsports front coil over/spring kit
    granatelli motorsport upper and lower control arms
    koni adjustable shocks/struts
    moser 28 spline drag axles,long studs
    3.73 gears
    rear mounted battery
    255 intank pump
    cowl gauge concepts 2 pod cowl panel
    fuel press,boost,water temp,oil press, 5inch tach
    aftermarket cd player,speakers etc
    weld skinnies with newer tires
    weld 15x10's with 275-60-15 drag radials
    mac 1 3/4 long tubes
    mac prochamber
    dynomax bullet mufflers, dumped
    full length welded on subframe connectors
    ford 9mm plug wires
    msd cap,rotor,blaster coil
    crane hi6 ignition box..
    radiator mount coolant overflow
    plus im sure there is a ton more im forgetting...
    6500.00
    email ruthlessgsx@aol.com or call 814-207-3299 (pics available upon request)
    would trade for a 1st gen lightning
    NEWB
    altoona,p.a
    299
    new price is 5500.00 i found somthing i want to buy....
    NEWB
    altoona,p.a
    299
    bump...needs to go
    MR. WINDSOR 351SVT's Avatar
    136
    I did have a black 93 lx i wish i didn't get rid of.
    Senior Member 95gts's Avatar
    Sep 2008
    Brownsville
    290
    Any pics?
    95 Mustang gts... Cobra intake,GT40P heads, F-cam, sds efi, 60lb injectors, Garrett turbo 11lb's!!!
    Still for sale?
    ChuckT
    Sponsored by
    Millerstown Pic A Part
    ILLBEATU fastfox91's Avatar
    huntingdon,pa
    830
    this sold a while back
  1. 2002 modded mustang gt sale trade
    By chuck94 in forum Ford Vehicles
    Last Post: 12-16-2014, 05:02 PM
  2. Opinions wanted: Modded Terminator or Modded C5?
    By Stangman701 in forum The Bar
    Last Post: 12-22-2011, 03:44 PM
  3. 2000 Mustang Modded GT For Sale
    By Darren in forum Ford Vehicles
    Last Post: 06-04-2011, 08:19 PM
  4. 1999 Mustang V6 5spd Modded
    By TheGreatWhite in forum Ford Vehicles
    Last Post: 08-24-2010, 06:52 AM
  5. 1989 Mustang Notchback Modded
    Last Post: 10-16-2006, 12:45 PM
