Results 1 to 3 of 3
Thread: Odd creaking/clutch life
    needs boost! wishIhada5.0's Avatar
    May 2008
    right outside of Greensburg
    352
    When I pull out and when I roll into the gas from about 1200-2500 rpm I get a really annoying creaking sound. I dont know how to describe it other than maybe a worn motor mount bushing or something of that sort. Also, how do I go about checking the clutch and flywheel without removing the whole tranny? It has 73k miles on it and still has the original clutch to my knowledge. It still grabs really well and it starts to engage about 2 inches from the floor in the pedal travel. However, if I grab 3rd real hard it will screech for a split second. It will only chirp the tires once in a while going into third and when it does slip for that split second it doesnt slip enough for the rpm's to spike. thanks guys
    Dan
    sounds like the motor is prob moving around, if you stop down the shop, I can take a look at it..
    May 2008
    352
    What would cause it mounts to weaken all of the sudden if thats the case?
  1. Odd charging issue
    By cwh19 in forum Fox-SN95
    Last Post: 05-22-2013, 07:00 AM
  2. odd but cool
    By crusher101 in forum Wolfpack Speed
    Last Post: 02-06-2009, 09:20 AM
  3. Odd Vibration.
    Last Post: 09-26-2008, 05:53 PM
  4. Ok, I found this odd...
    By weareweird69 in forum S197
    Last Post: 10-17-2007, 09:16 AM
  5. very odd f350
    By 5k#Eaton in forum Pictures & Videos
    Last Post: 12-31-2006, 12:45 AM
