Results 1 to 8 of 8
Thread: WTB T-56 with 26 spline input shaft and quick time bell housing
    I've decided to stay with a manual transmission in my car, I know it will be slower at the track but the car sees much more street time than track time so I think this is the best way to go for me. I want a T-56 with an upgraded 26 spline input shaft and a quicktime bell housing as well. I'd also need the cross member and drivehshaft to put it in this car. Let me know if you or anyone else has one for sale. Once I find one my TKO will be for sale.
    Petersburg,PA. 16669
    816
    what tranny do you run now Paul?
    88 GT...and some boost
    A standard TKO (pre TKO500/600) with a promotion Kustom clutch and aluminum flywheel.
    816
    watching the vids you posted it looks like you shift that thing hard!!
    I tried that with mine and blew it apart! LOL
    you can't shift it any harder than he does ,i have tried .
    816
    yea I ain't shiftin it like that any more.I'm thinking of selling my TKO and going back to G Force.They love the gas pedal to the floor all the way through the gears
    never stock biminiLX's Avatar
    Beaver
    2,406
    I don't think you can shift a non-faceplated/proshifted TKO much faster.
    I shifted my regular TKO and current TKO600 about the same--just let off gas for just a split second to get it to shift.
    Since I've had my 600 fixed by ProMotion I really like it Paul. With a 3.50 gear and 28" tire I actually wish I would have got the less OD version but the other gear spacings are fine with the turbo and its lighter than a T56.
    Maybe look into the TR6060 version if you're going with a 6 gear? Better synchros and gearing from what I've seen.
    Sep 2008
    72
    Here is a pretty good deal that I found on just the trans. http://forums.corral.net/forums/show....php?t=1074750
    Adam
    2003 cobra---sold
    2002 gt MPH long block with stage 3 2V heads, MPH custom grind cams, Kenne Bell 2.8H with MPH behemoth inlet, return fuel system, Zex nitrous kit(75 shot), 6-speed, built 8.8, etc. --SOLD
  1. Replies: 2
    Last Post: 12-09-2014, 09:51 PM
  2. wtb 26 spline imput shaft
    By ocrowner in forum Ford Parts
    Last Post: 03-31-2014, 11:38 PM
  3. Vortech input shaft problem
    By frankstang in forum Fox-SN95
    Last Post: 09-07-2012, 04:19 PM
  4. Input shaft question
    By yellowstang03 in forum General Tech
    Last Post: 09-21-2010, 06:36 PM
  5. C4 hardened input shaft breakage pix
    By mikeymustang in forum Pictures & Videos
    Last Post: 07-18-2007, 08:48 PM
