Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
Thread: Fox body fanatic
  1. #21
    On the down low cam303's Avatar
    978
    4.30's preferably. 4.10's minimum.
    Lots of gear fear around here.
  2. #22
    Quote Originally Posted by cam303 View Post
    With an S trim Chris? I wouldn't do more than a 3.73 personally if it was my car since its a H/C/I combo with a vortec. With the trap speeds he's likely to see it'd be over 6200rpms easily going through the traps. If he doesn't have numbers I assume that it hasn't been tuned and thus may have the stock rev limiter.
    How many lbs of boost are you seeing now with the pulley setup you have? Knowing that will make a HP guess easier.
  3. #23
    978
    Quote Originally Posted by Killercanary View Post
    I missed the s-trim part. Thought it was N/A. In that case 3.73's sound right.
  4. #24
    Turbo Trans Am=WEAKSAUCE
    Dec 2008
    Elizabeth, PA
    32
    About 7 1/2 lbs. I am thinking it's running rich, the thing sucks up gas pretty bad.
  5. #25
    Got Boost?
    West Mifflin
    1,442
    Welcome.
    3.73s FTW
    With some gears it should see 11s
    2013 Race Red F-150 Screw FX4 Ecoboost
    1994 Rio Red GT
    10.60 @122.88
    Sold
  6. #26
    Quote Originally Posted by Rio94gt View Post
    Welcome.
    3.73s FTW
    And traction, Lol.
  7. #27
    Dec 2008
    Elizabeth, PA
    32
    Welcome.
    3.73s FTW
    I have been looking around some other forums and I see most supercharged 306's are in the 12's. I want to be in the 11's, though. A small cube motor like this 306 would be hard pressed to get into the 11's N/A. I am not talking about some high compression, pop up piston, solid roller, carbed 306.
  8. #28
    never stock biminiLX's Avatar
    Beaver
    2,406
    Quote Originally Posted by George View Post
    You should definitely be able to get into the 11s w/ gears, traction and practice. You'll trap close to 120mph which is easily 11 sec. potential but ET depends on alot of factors.
    I'd suggest 3.55-3.73 gears depending on how you use the car and what tire.
    Any pics?
    Love to have more Foxbody guys here
  9. #29
    HAHAHAHAH We have a member with a 302 hittin low 10's N/A. Stock bottom end.
  10. #30
    http://www.steelcitystangs.com/forum...ad.php?t=12351
    Somewhere in tis site there are vids of this car.
  11. #31
    Beaver
    2,406
    true, but by FAR the exception and a race car set-up.
    If this guy has never been to the track, he should be happy w/ 12s IMO.
  12. #32
    Got Boost?
    West Mifflin
    1,442
    I went 10.60 on a stock 302 w/ GT40 iron heads.
    1994 Rio Red GT
    10.60 @122.88
    Sold
  13. #33
    Yes J, you are corect there.
  14. #34
    Senior Member DMmustangLX's Avatar
    May 2008
    Pittsburgh
    229
    3.55 or 3.73's and traction u should be in 11's
    01' Gt=
    Mac 2.5 in. prochamber with high flow cats, mac exhaust, steeda strut tower brace and bbk alum. underdrive pullies and more to come
    87' Notchback 5.0 =
    3.55's, rebuilt t-5, upper and lower control arms, steeda subframes, torque box reinforcements, mac girdle, s.s brake lines, b.s flywheel, ram hd powergrip clutch, steeda adj. clutch cable kit, steeda tri-ax and way to much other stuff to list
  15. #35
    Dec 2008
    Elizabeth, PA
    32
    That's really hard to believe there. Probably a 347 and claiming it's a 302. Or hitting it with a shot of laughing gas.
  16. #36
    TELL IT LIKE IT IS crazylou's Avatar
    Nov 2008
    ELIZABETH TWP.
    885
    I Kno Sum1 That Went 10.40's Stock Bottom,heads,intake,turbo So Anything Is Poss.
  17. #37
    No, it's true. Good combo with weight reduction, steep gears, traction and great driving.
  18. #38
    Beaver
    2,406
    Yep and mineshaft DA I believe also, car and driver really get it done
  19. #39
    You dont need cubes to run pal. He proves it. I know him very well. No juice, straight na. Very well thought out combo and good driving. The bottom end bearing caps have never been cracked loose.
  1. Replies: 0
    Last Post: 06-03-2014, 08:46 AM
  2. My old 91 fox body.
    By 89stang in forum Fox-SN95
    Last Post: 06-03-2013, 12:00 PM
  3. Not new, but another fox body
    By gt420hp in forum Welcome New Members
    Last Post: 10-07-2011, 09:52 AM
  4. Fox body
    By 89stang in forum Ford Parts
    Last Post: 11-24-2009, 06:07 PM
  5. Looking for Fox Body
    By molnartr in forum Ford Parts
    Last Post: 10-01-2007, 02:20 PM
