Results 1 to 20 of 25
Thread: Max. rear tire / wheel size
    Go big or go home... gmslayer's Avatar
    Nov 2008
    Latrobe, PA
    347
    Anyone out there know the maximum rear tire / wheel size you can use on a 1993 LX??? I have a 1.5" lowering springs and a stock 8.8 rear.
    Thanks.
    Mt Pleasant
    2,916
    the biggest ive had with a lowered fox is a 17x10.5 with a 275/4017 tire. they rubbed a little though
    slicks would check in around 26x10.50, you can fit bigger tires but you need to do a few things..
    Not to confuse things Tim, but are you talking a true slick or an ET Street?? I suspect ET street as most slicks are even sized (9", 10")
    To that point, I had 27-10.50-15 ET streets on 15 x 8" wheels (5.5 BS) on my Capri, and it was about as tight as it gets. Guys do run 15 x 10 wheels, but I cant see one ever working on my car (even with a BFH)
    No real help for you on street tires, 245/50/16 is about as far as I've even pushed them on a fox.........
    LowHill
    2,679
    275/40/17's on stock Bullitts with no quad shocks.
    Polar Vortex
    6,031
    Bob, was this with the QS's flipped or no QS's at all??
    What's a quad shock??? LOL, I removed the quad shock brackets from this rear before it even went in the car. For sure they wouldnt fit on my car if it had quads.
    On edit: By the way, those where ET Streets. I now run Hoosier QTP's in the "same" size, but they have way less sidewall bulge and maybe / possibly could fit with quads. Not sure (they are off the car if you wanna try a fit ;) )
    ET street at launch, pretty clear here I wasnt getting away with much more ;)
    I could probably go a little bigger now with the baseline suspensio nas it removed all that "squat"
    Nov 2008
    Latrobe, PA
    347
    What would be the largest combo for the street?
    never stock biminiLX's Avatar
    Beaver
    2,406
    I've had 315/35/17 Nitto DRs on 17x9 Cobra Rs w/ only outer fender rolling, no rubbing or problems also lowered about 1-1.5".
    Also had 26x11.5x16 ET Streets on factory Ponies and 275/50 MT DRs on 15x10 Bogarts w/o problems.
    My brother has 305/35/18 Nitto DRs on 18x10s w/ inner and outer fender clearencing, but expect rubbing lowered that much.
    For any serious tire on a Fox you have to roll the outer lips, anything else is a waste of time.
    Beaver
    2,406
    Quote Originally Posted by gmslayer View Post
    What size wheel?
    You can do 15-18" if you know what you're doing.
    Nov 2008
    Latrobe, PA
    347
    I was thinking 17 x 10.5 with 315's.
    Beaver
    2,406
    Doable but tuff, what axles--fox or SN95?
    Castle Shannon
    1,276
    imma gonna try 255/50s on oem bullitts with a 99 rear... i'll let yinz know how it goes
    Nov 2008
    Latrobe, PA
    347
    stock fox rear.
    if you roll the fender lips and square off the rear tubs, you shoiuld have NO problems at all..
    Petersburg,PA. 16669
    816
    the lowering springs are really gonna limit you
    I have 15x10's with 6.5 bs on mine and used 28/10 slicks and I have a 88 GT
    88 GT...and some boost
    May 2008
    Pittsburgh
    229
    what would be a good size drag radial to run on a 16" pony rim. if neone has ne ideas on a brand and size let me know would like to get a set for p.r.p and F.L.D's this summer , thanks guys
    01' Gt=
    87' Notchback 5.0 =
    816
    Quote Originally Posted by DMmustangLX View Post
    16" ones are limited.I'd use 255/50's
    May 2008
    Pittsburgh
    229
    will i have to roll the fenders for these, i do not have ne quad shocks on it. i eventually want to get some rims and a five lug conversion so that i can run a bigger tire thanks 4 the help
    01' Gt=
    87' Notchback 5.0 =
    816
    doubt it on a pony wheels since of the7" width and the deep backspace
  1. rear tire size for my 1991 lx
    By Ckelly91lx5.0 in forum Fox-SN95
    Last Post: 06-09-2012, 07:32 PM
  2. Rear tire size help
    By 84QuadEye in forum General Tech
    Last Post: 03-08-2011, 12:59 AM
  3. Terminator: Will 16" wheels fit rear? Tire size max?
    By 03SnakePlissken in forum SN95-New Edge
    Last Post: 10-01-2009, 01:44 PM
  4. Max tire size?
    Last Post: 02-20-2008, 02:14 AM
  5. Max tire size on stock terminator wheels ?(56k Warning!)
    By axles of evil in forum SN95-New Edge
    Last Post: 02-28-2007, 08:47 PM
