Hello all! Here is a little bit of info on my car! I hope to boost it in the near future.
1999 35th Anniversary Limited EditionFactory options
-limited edition ground effects
-limited edition spoiler
-limited edition trunk option
-17x8 5 spoke rims
-2 tone leather
-air conditioner
-cd player
-power steering, windows, seat, sunroof
-manual transmision
-traction control
-cruise control
-keyless entry
Engine options
-4.6 liter 2valve v8 motor
-8 bolt crank
-performance improved cylinder heads
-forged cobra crank
-manley h beams rods
-manley dome dished platinum pistons
-10.5.1 compression
-manley stainless valves
-manley behive springs
-comp cam cams
-bbk timing advancer
-under drive pulleys
-80mm c&l mass air flow
-70mm throttle body
-hays street/strip clutch
-pro 5.0 short shifter kit
-steeda firewall cable adjuster
-aluminum drive shaft
-3.73 gears
Suspension options
-welded subframe connectors
-KYB gas shocks
-polyurethane replacement mounts
-1.5 inch Eibach lowering springs
-camber plates
-KYB rear kicker shock set up
-rear main girdel
Misc. options
-17x8 bullit rims
Exhaust options
-Ford Motorsports stainless headers
-Pypes brand x pipe w/cat delete
-Magnaflow axle back mufflers
-4 inch tips
