Lookin good!!![]()
Lookin good!!![]()
LOL, we will see ;) As long as neither of us move up to mod, it's going to be a wash at 12.00 :D Sandbagger showdown.
Car already has 55#'s in it, this turbo will out flow them although I do plan to start out there. I don't want to chase tuning 75# injectors while sorting everything else. Mass air is mandatory, and will be worked out as part of the new combo ;)
Agreed, although mine being a stick is better. The Buick stuff you had to deal with converter flash as well. Mine leaves off the limiter on a clutch drop, so it's better there. Between the 4 cylinder, stick, and turbo, dialing to the tenth is enough of a challenge although the old combo would run within .04 worst case any given day and most of that was 60'. This should be better, we will see ;)
yeah let me know about the waste gate bob i don't have one yet,
Great looking turbo!
yeah that looks great ,nice job
that's gonna be sick!
Did You Paint It After Wraping? Or Is The Wrap That Color?
Also would like to hear your review on the wrap Bob, I plan on doing my headers in that black.
I bought the black wrap (DEI). the wrap itself is relatively easy to work with if you take your time and work the details to get it tight and right. For the four runners and the collector, I spent maybe an hour and a half fiddling with it to make it the way I wanted. The biggest time for me was in the middle at the collector where the tubes come together, the tubes are really easy. After wrapping it, it is coated with the DEI black "silcone" wrap spray. I swear to you it is nothing more than high temp black paint, but we will see. The spray is supposed to help hold it in place, make it more waterproof, and resist rot. We will see long term. I expect the header to crack long before the wrap is an issue ;) 1600 F EGT's tend to do that :D
Thanks Bob, that was the kit I was planning to use.
i think i am going to try swain tech on mine, then wrap it .
wow thats awsome , that should flow a little better than the stock elbow
That Swain tech stuff is supposed to be the sh1t. I'm going to do my DP with it. I'd wait to wrap it to see if your good w/o it. It will come back white but you can paint any high temp over it.
Only going to DEI wrap the headers and crossover because I have a nice high temp black coating thats holding up nice and want the wrap for the heat protection.
And lookin' good Bob.
I wanna see this car run this year..
Have been out of town for a while here, lots of parts came, but nothing 100% (damn backorders ;) ). I did get the rest of the V-Band parts, all the bits to build the downpipe, plus most of the oil line stuff. I need to get the return line done, and of course what I'm missing is for that
Anyway, couple pics of the V-Band assembly to start the downpipe.
This stuff is sweet! Basically loosen the clamp and I can drop the exhaust. I'm thinking about using some of these for intercooler piping too. They arent cheap, but should never fail / leak / blow out, and not that bad if you look at the price of a coupler and two t-bolt clamps versus one set of flanges and clamp.
Hopefully more parts come this week :D
