Results 1 to 20 of 38
Thread: Clutch Issues
    Lovin my 302
    Chicora, Pa
    116
    Clutch Issues
    Hello everyone, I've been having trouble with my clutch cable snapping from time to time. I'm now in my Th cable and getting very fed up. I have a Tremec T5 with Lakewood blow proof bell housing, Lakewood clutch fork and pivot ball a ford racing fly wheel a king cobra clutch. I'm using a Jegs 3 peace set cable, quadrant and firewall adjuster. Any ideas why this might keep happening? before the cable breaks and leaves me stranded it always gets hard to push the pedal and its all down hill from there.
    What are some of you guys running with the Lakewood set up or what should I be using different?
    Thank you, Chris
    Jan 2008
    Jefferson
    4,674
    i heard factory ford cables are the best too run. try finding a factory 03-04 cobra cable. thats gonna be your best bet. if that brakes you have a serious issue
    Lovin my 302
    Chicora, Pa
    116
    Thank you I will see what I can find. Any one using a fire wall adjuster?
    Pittsburgh, Pa
    459
    X2... factory Ford cables seem to be the strongest.
    Pretty sure there is nothing special about the '03/'04 cobra cables. They are all the same on the Sn-95 and New Edge chassis'. I personally am using the stock cable with a steeda quadrant and UPR Microclick firewall adjuster. Also have a pedal height adjuster underdash. NO PROBLEMS at all.
    I have a UPR double-lock firewall adjuster here if you want it Just shoot me a PM.
    http://www.uprproducts.com/shopping/shopexd.asp?id=557
    shaler,pa
    1,010
    I will agree his car is nice can power shift it easy hahahaha
    89 Mustang (stock) DD
    82 Trans Am (not stock)
    98 Audi A4 (not so hurting)
    ruffsdale
    3,625
    i got a factory cable brand new $20 should be the same i bought it for my 93 gt
    Jan 2008
    Jefferson
    4,674
    I use a steeda firewall adjuster and quadrant. Both are nice pieces. I'd recommend steeda.
    Lovin my 302
    Chicora, Pa
    116
    Thank everyone! Looks like ill be getting a ford cable, will the firewall adjuster work with a stock ford cable?
    Pittsburgh, Pa
    459
    Yes
    Lovin my 302
    Chicora, Pa
    116
    very nice! thank you
    Member torqueboxer's Avatar
    white oak, pa
    638
    is the clutch fork longer than stock? ive had the same cable on my car for 5-6 years with 4-5 clutches and havent broken one yet. i have a lakewood scatter shield but i lengthened my clutch fork about an inch to keep the cable parallel with the bellhousing does yours run at an angle? mine is straight with the longer fork. how is your front bearing retainer? if its all scored up that will make the pedal real hard to push. there is something wrong if your chewing up cables
    Wrap the cable with header wrap.Its probably getting hot and melting the inner liner. Thats what happened to mine 4 times. Header wrap on the cable and on the long tubes and problem solved.
    Lovin my 302
    Chicora, Pa
    116
    I have a lakewood stock length clutch fork seems to be straight, its kinda close to the bellhousing. its a new bearing. Thank you
    Lovin my 302
    Chicora, Pa
    116
    that could be possible but i've only had the long tubes on for about a week and did the clutch again at the same time and cable is not melted yet atleast.
    2,247
    My dad has a steeda firewall adjuster and quadrant and for about 2 years it was GREAT! then when the cable wore out a guy he knows put a new STOCK cable in at his shop and it broke multiple times since then. Dad called Lou and he sold him a new cable (not sure on brands or what) and it has not been a problem since.
    Black
    white oak, pa
    638
    if the clutch fork is the same length as stock thats the problem. the mounting location where the cable slides through the bell housing is further away from the centerline of the tranny. if you look up towords the bottom of your bell housingis the cable perfectly parallel with the bell or is it running at an angle? ill bet its at a pretty steep angle. AFM sells an extended clutch fork that corrects this problem, if you cant cut and extend the fork yourself.
    May 2008
    Pittsburgh
    229
    x2 on that i got the steeda kit works great, lou actually recommended it
    01' Gt=
    87' Notchback 5.0 =
    Lovin my 302
    Chicora, Pa
    116
    Well I just got my car in the air and looked closer it is actually off about .25 of an inch. Thank you
    Quote Originally Posted by 955.0 View Post
    Its not visible. It melts the inner liner as I stated.
    pa
    860
    955.0 Your not from Pittsburgh! Be proud! say your from CHICORA!
  1. c-4 issues
    By black 94 in forum Fox-SN95
    Last Post: 08-27-2012, 01:31 PM
  2. I have issues.......
    By Dan B. in forum Other Ford
    Last Post: 04-25-2012, 06:27 PM
  3. A few issues/questions
    Last Post: 06-29-2007, 09:24 AM
  4. 95 5.0 issues
    By 955.0 in forum Fox-SN95
    Last Post: 12-01-2006, 10:36 AM
  5. spec 2 clutch issues
    By venom in forum Fox-SN95
    Last Post: 10-25-2006, 10:55 PM
