Results 1 to 14 of 14
Thread: 1991 mustang gt problem
    817
    car will fire right up in morning an run great but as soon as u shut it off it wont start you gotta hold it to the floor to fire back up but sometimes it wont start at all? i changed collant temp sensor,module on distributor,new plugs wires cap rotor button but still no better also it got a bout 38 psi fuel pressure any suggestions what to do next!
    Selinsgrove, PA
    526
    i didnt see new dist. on that list of things, my guess is the pip pickup in the dist. Ive heard its a real bitch to do, so the easiest thing is to get a new dist. (or used that is good)
    Fox/n.
    817
    forgot to mention changed distriutor too i thought of that too
    Petersburg,PA. 16669
    816
    the problem with the car is it is too rich at startup
    did you change the temp sensor in the coolant crossover pipe?
    88 GT...and some boost
    State College, PA
    3,552
    TFI module??
    2013 Mustang GT
    1999 Contour SVT
    817
    no i didnt change the one in crossover pipe i will try that
    817
    changed module gonna try crossover collant temp sensor
    Quote Originally Posted by chuck94 View Post
    yes, the one in the intake is for the guage, the one in the cross over pipe is for the ecu..
    816
    yea the sensor in the intake is for the gauge
    I had the same problem as you and it was the sensor in the pipe.I actually had the wrong plug on it and switched the plug back and worked fine
    Gibsonia, PA
    323
    I read that this symptom could be caused by an ECT (Engine Coolant Temp) sensor.
    1,220
    A couple other things it could be EEC relay, fuel pump relay. When it won't start does it have spark and or fuel pressure?
    816
    Quote Originally Posted by 95DropTop View Post
    that is the one I told him to change
    Gibsonia, PA
    323
    Yeah, I didn't read your post carefully enough. Sorry.
    816
    np.alot of people confuse the 2 and don't realize the one in the intake is for the gauge
  1. 1991 Mustang Codes
    By Zoom50 in forum Fox-SN95
    Last Post: 06-01-2014, 02:49 PM
  2. 1991 Ford Mustang 5.0 Coupe
    Last Post: 03-31-2010, 10:43 AM
  3. F/s 1991 Mustang Gt
    By jclose11 in forum Ford Vehicles
    Last Post: 01-19-2010, 10:47 AM
  4. FS-1991 Mustang LX Vert
    By WickedJester in forum Ford Vehicles
    Last Post: 05-23-2008, 12:20 PM
