Results 1 to 9 of 9
Thread: Roller spider + Non Roller Block ??
    Anyone know if I can drill/tap a non roller block to make a roller lifter spider work in a 351w? I'll use t-bar lifters if I have to.
    LowHill
    2,679
    I belive you can, but I think I heard the threads pulled out on someones before
    Member torqueboxer's Avatar
    white oak, pa
    638
    you can do it but youll be stuck running reduced base circle cams, if you spend the dough on the retrofit lifters you can run any cam designrd for a stock roller motor. the threads wont pull out there really isnt any pressure on the spider just the tension to hold the dogbones onto the block by the bent piece on the bottom of the spider
    LowHill
    2,679
    But on a H.O block where it bolts down isn't it raised where the threads are but not on a reg block?
    Hmm ok I'd rather not use a reduced base circle cam so this makes my decision easier.
    white oak, pa
    638
    yea its rough spending all the $$$ on the lifters but its the way to go for the future, cam selection, the solid rollers are about 150$$ less and the comp line of xr's are very streetable
    Big Daddy gmkillr's Avatar
    At the racetrack
    4,193
    Just buy the Comp Cam link-bar lifters and you'll be miles ahead.
    Check out www.fordstrokers.com
    For some great pricing on them.
    Corvette Z06
    The comp link bar lifters are a really nice piece and work well. Jay allen at camshaft innovations can get you a really good deal on them too.
    Spoon Killer HidalgoGT's Avatar
    Uniontown
    1,792
    Think Lou has a set of those lifters for sale. Wouldnt work for me.
    Got Smoke?
  1. Replies: 14
    Last Post: 02-22-2014, 12:52 PM
  2. 351w roller block
    By blk93notch in forum Fox-SN95
    Last Post: 06-03-2011, 11:13 PM
  3. 5.0 ho roller short block
    By fast4ord in forum Ford Parts
    Last Post: 05-09-2009, 09:32 PM
  4. wtb 351w roller engine, block or pre 74 block
    By tjvantana in forum Ford Parts
    Last Post: 04-08-2009, 10:27 AM
  5. 5.0 roller block for sale
    By TJH64 in forum Ford Vehicles
    Last Post: 01-10-2009, 12:14 PM
