Im having a problem with my car not starting when i turn the key. This is on a foxbody BTW....
when i put the key in the Start position, nothing happens with the starter, not even a click. my starter relay is fine (i am assuming, because i can jump the starter and start the car) and using a test light i was able to discover that i am not getting power to the little wire that plugs into the top of the starter relay when the key is in the Start position like i should. i dont know what i causing this.
i also discovered a wire that does not appear to be factory running from the positive battery cable in the first picture to a relay behind the dash in the second picture...it has a 15 amp fuse on it and i tested the fuse and the fuse is fine...so, what the heck is this wire for???
