Results 1 to 12 of 12
Thread: Electrical issue
    State College, PA
    3,552
    Electrical issue
    Im having a problem with my car not starting when i turn the key. This is on a foxbody BTW....
    when i put the key in the Start position, nothing happens with the starter, not even a click. my starter relay is fine (i am assuming, because i can jump the starter and start the car) and using a test light i was able to discover that i am not getting power to the little wire that plugs into the top of the starter relay when the key is in the Start position like i should. i dont know what i causing this.
    i also discovered a wire that does not appear to be factory running from the positive battery cable in the first picture to a relay behind the dash in the second picture...it has a 15 amp fuse on it and i tested the fuse and the fuse is fine...so, what the heck is this wire for???
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    State College, PA
    3,552
    is that wire what is powering the relay??
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Looks like that wire was put in to allow the driving lights to be run without the headlights.
    State College, PA
    3,552
    ya the fog lights were re-wired, i talked to the previous owner about it, and i think that wire is just powering that relay, but wasn't sure.
    but what could be causing me to not get power to the little boot that plugs into the top of the starter relay? my fuseable links look good, but how can i be sure they are good? dont the wires look melted when they go bad?
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Is the car driveable? If so, if you can get it out to my Dad's, I'd be happy to help you fix it.
    State College, PA
    3,552
    not quite yet...it has no brake fluid in the master cylinder so i need to bleed all the brakes still and definitley need new tires, they are just old, dry-rotted junkers that i threw on and one doesnt hold air well
    and its not inspected or registered yet lol
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Well, let me know when you can bring it up if you can't get it figured out.
    train kept a rollin! thebreeze72's Avatar
    Jun 2008
    u-town
    343
    no start prop.
    try the ignition switch on the stering colum and check the connector also they burn up easy and are prob. oem. also did you jump the solenoid or did you just but voltage directly to the starter case itself?
    State College, PA
    3,552
    Quote Originally Posted by thebreeze72 View Post
    i put a jumper cable on the positive battery post and touched the other end to the small post on top of the relay to crank the starter
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
  1. Chasing an electrical issue - 94 GT lock switch
    By J-rod in forum General Tech
    Last Post: 06-23-2014, 01:44 PM
  2. Electrical Questions
    By Tony71502 in forum General Tech
    Last Post: 08-11-2009, 02:14 PM
  3. Electrical Help.
    By Rio94gt in forum General Tech
    Last Post: 05-24-2007, 06:51 PM
  4. i have electrical problems too
    Last Post: 05-11-2007, 01:34 PM
  5. Electrical Issue
    By RUSH2112 in forum General Tech
    Last Post: 05-10-2007, 11:15 PM
