Results 1 to 6 of 6
Thread: Should I go to 3:90's or 4:10's with 28" tire
    Morgantown WV.
    563
    If I go from a 26" to a 28" rear tire and an auto, should I also consider switching out the 3:73's for a little steeper gear?
    665/540 New times coming
    give it a try first.. but the 373s sound to be more suited for your car..
    never stock biminiLX's Avatar
    Beaver
    2,406
    I base the rear gear on where you want the rpm going through the traps.
    Look at some of the online calculators and you will have to guess converter slip also.
    Morgantown WV.
    563
    A guy gave a link that has a calc for conv slip too.
    http://www.tciauto.com/Products/TechInfo/Calculators.asp#4
    According to those calculators.
    If I run 3.73's with 28" tires, a 1.1 trans ratio in drive, with a converter slip of -0.0106%, Which I deterimined using the calculator for determing converter slip. I will be going 130 at 6400 rpm? Does this sound correct?
    What's weird to me is that is says at 6500 I would only be going 128, with all the other varibles being the same except the converter slip goes to 1.55171% at 6500rpm. Could only 100 more rpm make such a huge difference in converter slip, causing the MPH to lower?
    I think I might have did something wrong.
    Here's a pic of the calculators
    First pic shows calcs for converter slip and mph @ 6400rpm
    Second Pic pic shows calcs for converter slip and mph @ 6500rpm
    2,247
    I would go 4.10's. a friend of mine had 3.73's in his 06GT auto and when he put the 4.10's in it ran a lot better than with 3.73's. 4.10's FTW in an auto!
    Black
    Morgantown WV.
    563
    Quote Originally Posted by Shorty429 View Post
    I think it has a lot to do with how much power you're making also. I don't want to exceed 6500 in drive when I go through traps at the track.
  1. 2005 tire size 18"
    By Hankwedge in forum S197
    Last Post: 07-10-2013, 01:00 PM
  2. WTB: 27" or 26" x 10.5 x 15 Bias Tire - M/T, MH, Hoosier
    By somethingclever in forum Ford Parts
    Last Post: 10-13-2011, 08:40 AM
  3. Tire Help (17" Bullet)
    By mr4teth in forum General Tech
    Last Post: 04-18-2010, 09:05 AM
  4. M/T ET Streets DOT 16" 28X12.5 true 10" tire
    By Dave King in forum Ford Vehicles
    Last Post: 03-15-2009, 10:12 PM
  5. M/T ET Streets DOT 16" 28X12.5 true 10" tire
    Last Post: 05-11-2007, 12:44 PM
