Results 1 to 13 of 13
Thread: 5.0 roller block for sale
Hybrid View
    Senior Member TJH64's Avatar
    Delmont PA
    320
    I bought this 94 302 roller block off of gmkillr. Had my 347 professionally built, so I don't need this.
    -.030 overbore
    - Align-honed
    - Stroker clearanced
    - No cam bearings or freeze plugs installed
    Ready for assembly. $100
    Will deliver locally
    Petersburg,PA. 16669
    816
    was that block decked?
    88 GT...and some boost
    Delmont PA
    320
    No I don't believe it was.
    816
    they cylinders chamfered at the top of the bores?
    Delmont PA
    320
    I'll go check. I'll post a pic
    Delmont PA
    320
    It does not appear to be chamfered. I felt the top of the bores, and they have an almost indistinguishable slight radius. I believe the flash is creating the appearance of the chamfer??
    816
    ok thanks
    816
    is there a sharp burr where the deck surface meets the bore
    Delmont PA
    320
    No not at all.
    I ran my finger around the bores- nothing sharp
    816
    ok it's just a matter of me findng the time to come get it.I should be able to next weekend if that is ok with you.
    Delmont PA
    320
    That is fine with me. I can meet you halfway somewhere??
    I'll pm you my phone #
    Thanks!
    TJ
    816
    that works for me.Thanks
    Delmont PA
    320
    This is still available!
  1. Replies: 14
    Last Post: 02-22-2014, 12:52 PM
  2. Wanted- 5.0 roller block
    By Sonic03snake in forum Ford Parts
    Last Post: 06-21-2012, 12:03 AM
  3. 351w roller block
    By blk93notch in forum Ford Vehicles
    Last Post: 09-11-2011, 09:57 PM
  4. wtb 351w roller engine, block or pre 74 block
    Last Post: 04-08-2009, 10:27 AM
  5. Roller spider + Non Roller Block ??
    By Ares in forum Fox-SN95
    Last Post: 12-28-2008, 10:53 PM
