Results 1 to 6 of 6
Thread: aod to t-5 swap
    aod to t-5 swap
    hey anyone done this ?do i need another harness for back up lights and stuff?thanks
    Belle Vernon
    1,294
    I took the T-5 out of my grey car and put in a AOD and I believe the sensor for the back up lights and neutral safety is different. Its been five years since and can't quite remember. I cut the plug of a car that was an automatic and just wired it up. Like I aid though I can't remember what I did but I had to do something.
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
    1,220
    I have done it on a Fox. There is a jumper harness off the main harness for the transmission type. (AOD or T5) If you are getting the stuff from a donor car it should have what you need.
    Jan 2008
    Jefferson
    4,674
    ive done it. you can use your factory wiring harness and just take the two wires out for the reverse lights. if you keep the facotry harness you must keep the neutral safty switch! i did much cheaper than buying a new one
    i have all most all the parts for the swap except for a quadrant and cable and the wiring
    Senior Member 95gts's Avatar
    Sep 2008
    Brownsville
    290
    I did it on the turbocoupe and I think they were the same.
    95 Mustang gts... Cobra intake,GT40P heads, F-cam, sds efi, 60lb injectors, Garrett turbo 11lb's!!!
  1. AOD help....
    By GOBLIN in forum Fox-SN95
    Last Post: 01-23-2012, 05:50 PM
  2. Aod
    Last Post: 11-25-2010, 09:24 AM
  3. aod to tko 600 swap
    By red92gt in forum General Tech
    Last Post: 08-27-2010, 01:19 AM
  4. t5 to aod swap
    Last Post: 01-11-2008, 01:15 PM
  5. complete t5-AOD swap
    Last Post: 12-02-2007, 11:44 AM
