I need to order new axles and I need to know if I have rear abs or not before I can order
if you were to take a wheel off, it would look like a cog at the end of the axle.
1986 GT:331, Edelbrock Vic Jr heads, Jay Allen custom cam, TFS R intake, 30# injectors, 75mm t-body, 80mm PRO-M, AFM Powerpipe, BBK 1 3/4 long tubes, BBK X pipe, 4.10s, 5 lug conversion, 99GT rims/Nitto DRs, PBR brakes, Lakewood 50/50s, Moroso rear drag springs, Sub frames, 2.5" cowl, Saleen spoiler
Power of a low 12 second car, Traction of a high 14 second car!
Mustangs came with ABS..or NO ABS..never just rear wheel abs. If you have abs sensors on the front hub/spindle...then you have ABS..which would be 4wheel abs
Also you can turn the key on and if the abs light comes on you got it. I know when i got my moser axles they were the same whether it had abs or not. You just had to press off the sensor rings and put them on the new axles
06 Custom Hardtail Honda SS750
00 Yamaha V Star 1100
88 Ford F250
