Results 1 to 8 of 8
Thread: No power to starter relay...need some help
    State College, PA
    3,552
    ok this is getting on my nerves here trying to figure out why im not getting power to the little boot going to my starter relay. the boot i am referring to is in this pic:
    EVERYTHING else in my car works...all lights, horn, fuel pump, etc. and my car will run if i jump the starter, but i cannot get it to start with the key.
    i was under my dash today messing around with a test light.... i pulled the two plugs out of the clutch safety switch (because i didnt know which one came from the ignition and which one went out to the relay) and i tested them both with the key in the START position, and neither was getting power. So i started poking the little needle on the test light into where the wires go into the ignition switch....i found that on most wires, i am getting power when the key is in the ON position but the power is not there when i move the key to the START position.
    Does this mean i have a bad ignition switch???
    2013 Mustang GT
    1999 Contour SVT
    Member badstanglx's Avatar
    altoona
    676
    u try jumping the neval safey switch
    State College, PA
    3,552
    Quote Originally Posted by badstanglx View Post
    how do i do that?
    2013 Mustang GT
    1999 Contour SVT
    2,483
    There is a white with pink striped wire coming out of the ignition switch. It is hot with the key in start. It is white/pink all the way to the neutral safety switch. When it comes out of the n/s it is red with light blue stripe all the way to the relay. I couldn't trace the wire from the ignition to the n/s. So I said f' it and ran a wire from the ignition straight to the solenoid. Its a big no-no to do this ('cause the car will now try to turn over in gear) and I plan on fixing it when the weather it nice, but it let me continue with the project for now. Not sure if the colors are the same for later years, but mine is an '87.
    http://www.autozone.com/servlet/UiBr...3d8016713c.jsp
    State College, PA
    3,552
    thanks for that info...i wasnt sure which wire went from the ignition to the switch, so that will help alot! mine is an 87 as well so it should be the same
    2013 Mustang GT
    1999 Contour SVT
    altoona
    676
    u taKE THAT PLUG OUT U CAN PUT A FUSE IN PLACE OF IT
    2,483
    He wasn't getting power to the harness on the neutral safety. Problem was further up the feed.
    State College, PA
    3,552
    yep i wasnt getting power to the safety switch so im going to test the proper wire on the ignition switch now that i know which one to check
    2013 Mustang GT
    1999 Contour SVT
  1. Turn signal relay - Help finding
    By roush08 in forum Fox-SN95
    Last Post: 05-13-2012, 09:18 AM
  2. Walbro GSL 392 inline pump and relay
    Last Post: 09-08-2009, 04:29 PM
  3. Electric fan, switch and relay
    By wick in forum Ford Vehicles
    Last Post: 04-13-2009, 09:48 PM
  4. fox body horn relay
    By PSPstang in forum Fox-SN95
    Last Post: 11-03-2007, 07:30 PM
  5. horn relay?
    By venom in forum Fox-SN95
    Last Post: 04-19-2007, 07:41 PM
