Things are coming togeter. My next problem is the vacuum lines. First I broke a vacuum line cluster. I hope to find a replacemnet or just replace it with rubber lines.
This is the harness I broke.
It plugs in here...
http://www.drrummel.com/Mustang/95Co...gConnector.jpg
I assume the pink line goes to the Air Pump Acuator...
The Green Lines goes to the EGR...
What does the Red Line hook to?
The fuel regualtor hookd the the vacumm nipple on the intake by the throttle Body. What hooks to the other prong on the nipple. The large port go to the PCV valve?
Does the Oil filler port hook to the air intake before the thottle body?
Finally,...
The vacuum lines under the upper intake...
I am going to hook up the large port to the vacuum tree/distribution. Where does the little port go to? I also have a tee in the hole by the bottem end. What hoooks to the two small ports on the tee?
Thanks.
