Results 1 to 17 of 17
Thread: Rear Main Seal 04 Cobra
    Administrator burntire's Avatar
    1,035
    I need to change my rear main seal. I see there is a retainer plate that appears to contain the seal. Has anyone changed a seal?
    2016 Mustang GT
    Jan 2008
    Jefferson
    4,674
    i dont know about the cobra motor but i didnt know there was a plate it just pry out????
    Jan 2008
    Jefferson
    4,674
    does it look like this??
    1,035
    It has a plate that looks like the seal is pressed into.
    2016 Mustang GT
    Jan 2008
    Jefferson
    4,674
    do you mean the silver part?? i guess you could take that off with the 6 bolts and then get the seal off. i dont see why you couldnt?
    Pittsburgh, Pa
    459
    You don't need to touch that plate. Treat it like any other rear main seal
    If for some reason you have a problem getting the seal out,,,, Then feel free to pull that plate. The seal will come out with it. Just be REAL cautious to clean all the silicone from the groove in the plate, and the block surface. And don't go nuts with the new stuff as you need that plate to sit flat against the block to hold the seal straight. IF NOT,,, you'll be doing this again next year
    Jan 2008
    Jefferson
    4,674
    Ya I never heard of taking a plate off that seemed weird. X2! Just pop it out like any other seal.
    1,035
    How do you seat the new one. It is a big diameter.
    2016 Mustang GT
    Jan 2008
    Jefferson
    4,674
    It should be the same size if that's what you mean. Just tap it in the a hammer. Be easy and try to put it in staight. Not one side at a time.
    Pittsburgh, Pa
    459
    Quote Originally Posted by burntire View Post
    Just take your time and "walk" a 3'8 extension around the outside of it with a small hammer. When you say bigger diameter, what exactly do you mean? It should be the exact dimensions of the one you removed???
    Mt Pleasant, PA
    4,905
    1,035
    $110. Send it out to me rich guy.
    2016 Mustang GT
    State College, PA
    3,552
    wow i cant believe how expensive that is! seems like such a simple tool
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    1,035
    The manual refers to an oil slinger and seal?
    2016 Mustang GT
    Jan 2008
    Jefferson
    4,674
    I don't think that tools worth it. Its very easy to take the old one out and tap the new one in gently.
    Pittsburgh, Pa
    459
    Call Ford, which is where I hope your getting your new seal from. I remember talking to the parts guy about that "slinger" piece, ordering it, AND SENDING IT BACK!!! Its just a metal ring that helps hold the seal in place. There should be nothing wrong with the one you have, assuming you dont bend it horribly when pulling it out. Just reuse it. It is the seal that goes bad.
    There is always a tool for the job, and someone whos found a way aroung using it. Take your pick...
    1,035
    Quote Originally Posted by Smallville View Post
    I ordered both.
    2016 Mustang GT
  1. Rear main seal replacement 03 Cobra
    By Terminated in forum SN95-New Edge
    Last Post: 02-01-2012, 02:49 PM
  2. SN-95 5.0 rear main seal replacement
    By Warrior1670 in forum Fox-SN95
    Last Post: 02-18-2011, 02:50 PM
  3. rear main seal questions???
    By White5.0 in forum Fox-SN95
    Last Post: 06-18-2010, 02:14 PM
  4. advice on changing rear main seal?
    Last Post: 04-06-2009, 06:40 PM
  5. It is never simple, which rear main seal?
    By DRRummel in forum Fox-SN95
    Last Post: 11-21-2008, 11:36 AM
