Results 1 to 20 of 22
Thread: Oil?
    Camal Clutch
    Aug 2008
    South Hills
    80
    Oil?
    I hate to make a thread on this but I did.....
    What weight oil to use? '99 GT
    5-20?
    5-30?
    I have been using 0-30 since I purchased the car. either amsoil or mobil1.
    ruffsdale
    3,625
    i use 5-20 mobil 1
    2013 Mustang Gt GHIG
    1978 F150 Camper Special
    1999 Harley softail
    1998 Buell Thunderbolt
    1997 Buell Thunderbolt
    Camal Clutch
    Aug 2008
    South Hills
    80
    i use 5-20 mobil 1
    that is why I made this thread.... 5-20 is what Ford recommends and next oil change will prob be 5-20.
    Spencerport, NY
    3,762
    I use nothing but Rotella T Synthetic 5W-40 in all of my high performance vehicles.... The R1, the CRF450R, and the Trans Am ... its the best oil you can buy, and it can be had far cheaper than the comparables.... I would suggest it, but also wouldn't argue if you wanted to stick with the 5-w20 that Ford recommends
    On the other hand, i use Mobil clean 5000 in the Harley truck... in a vehicle that's not beat on, i kinda think that as long as you change the oil faithfully and keep up with it, its not going to make a difference what oil you use... So i buy the clean 5000 b/c its SUPER cheap, made by a good name brand, and i change it @ 3000 miles faithfully.
    2015 Corvette Z06
    - Shark Grey / Kalahari
    Camal Clutch
    Aug 2008
    South Hills
    80
    here goes another question... What kind of oil change intervals would you suggest? I rarely drive my mustang (last year put on 400 miles) and use synthetic.
    Polar Vortex
    6,031
    In your case yearly.
    X2!!!
    Jan 2008
    Jefferson
    4,674
    I use what ford recommends. Otherwise its personal Preference IMO
    Camal Clutch
    Aug 2008
    South Hills
    80
    thanks guys. I usually change before winter and late spring/early summer. I missed the winter change this year was was freaking myself out a bit.
    2,145
    I use 5-30 mobil 1 extended protection (Gold cap). It is the best I have found so far along with K&N filters. I used it in my STI, Stealth TT, F150 and the Cobra and I have never had an issue.
    I change it twice a year in the Cobra. Once in the spring when i get it out and again when I put it away. (400miles last year lol) In the f150 I change it when it looks bad. 9k or so and it still looks ok when it comes out or when I see fit.
    Stock 03 Cobra Vroom Vroom!!
    pa
    860
    Can I have the old oil? I'll run that hardly used oil in the exploder!
    Fuwkawee
    5,151
    I run the Purple Stuff (Royal Purple) 5w30. It (my car) would be allright to go 4 to 5,000 but since its see's some track time I change it every 3,000
    17 Ram 1500 Big Horn Hemi
    16 Comp O GT Performance Pack
    needs boost! wishIhada5.0's Avatar
    May 2008
    right outside of Greensburg
    352
    I run mobil 1 5-20w with a Mobil filter...I decided to try an autolite thise time around so we'll see. Definetly dont run fram!!! I heard they break up and you get filter gauze everywhere internally. In your case once a year would be more than enough
    made some noise....and some boost...and 377/442 rwhp/rwtq
    Oct 2007
    creighton pa
    260
    check your owners manual again, a windsor pi motor (which is what should be in your '99 if it hasn't been changed) takes 5w30 not 5w20.
    2014 301a GT a6
    5c circle d conv, 3.31's, kooks l/t's & orh, stock intake, bmr susp
    Camal Clutch
    Aug 2008
    South Hills
    80
    Quote Originally Posted by casper gt View Post
    i thought there was a service bulletin saying that 99+ 4.6 2v should run 5-20....
    May 2008
    352
    I have an '02 and the fill cap says 5-20w :D
    Camal Clutch
    Aug 2008
    South Hills
    80
    Quote Originally Posted by wishIhada5.0 View Post
    hmmm?
    what to do?
    Oct 2007
    creighton pa
    260
    96-98 & mid01-04 (romeo engines) take 5w20. 99-early 01 (windsor engines) take 5w30. if you have a 99 & the eng. was not changed it should be 5w30 (but you can put in whatever you want).
    2014 301a GT a6
    Uniontown
    1,792
    I ran 5-30 Royal purple in my 04 and every 3500 it got changed i liked nitrous lol so I figured to be safe on wear change it every 3500.
    Got Smoke?
    Senior Member pop's stang's Avatar
    Dec 2008
    Belle Vernon, PA
    854
    Think with your dipstick Jimmy!!! LMAO
    "If speed wasn't important, it wouldn't be called the human race!"
  1. Replies: 7
    Last Post: 05-01-2010, 07:59 PM
  2. Motor Oil
    Last Post: 11-23-2009, 10:32 PM
  3. need help with oil pressure
    By blaze00 in forum Fox-SN95
    Last Post: 09-03-2009, 10:01 PM
  4. No Oil for Blood
    By map351 in forum The Bar
    Last Post: 09-18-2008, 08:30 PM
  5. Oil prices
    By Silverhatch in forum The Bar
    Last Post: 05-27-2008, 09:31 PM
