Results 1 to 19 of 19
Thread: TV guys help me figure out whats wrong
    State College, PA
    3,552
    Arrow TV guys help me figure out whats wrong
    at my house we have a samsung rear projection HDTV...we've had it for maybe 3 years now. about 6 months ago it developed this little white spot out of nowhere and it stays on the screen all the time no matter what you are watching. doesnt move or anything and its bright white. its very small but so annoying knowing it's there. what is causing this?
    ive had someone tell me that it means the bulb is going bad (on a rear projection tv you have to change the bulb a few times, but not often). I figured if that was the case, it would have gotten worse by now, but its been the same for about 6 months maybe more
    2013 Mustang GT
    1999 Contour SVT
    Senior Member 85stang's Avatar
    Sep 2007
    irwin
    227
    did you call a prof.? not best buy but a good repair shop that does the work. thell probably give you a definite answer and maybe even a repair cost. just a thought.
    85 mustang gt
    01 mustang
    06 F150
    65 t-bird (project)
    will:loco:
    Ligonier, PA
    6,365
    rhino i dunno if its plasma or not, but the plasma screens are comprised of millions of tiny bulbs, which burn out over time, usually leaving little black spots, but I dunno...if its plasma I would look into it, LCD then im not quite sure buddy.
    2018 Jeep Grand Cherokee
    1931 Ford Model A - Project
    1991 BMW 325iX
    1978 Ford F150
    1952 Ford F2 - Project
    Senior Member SUPERDUTY's Avatar
    Jan 2008
    181
    Quote Originally Posted by 2001GTTT View Post
    its rear projection looks as thought here is a spot on the inside of the screen most likely a pin hole could be caused by a bug or flaw in the screen. DIDn't you guys get it at voss? call them it could be fixed for nothing if in fact the screen is flawed. A bug can get into the backs and crawl around maybe bite it too
    2007 Hummer H2
    2006 Hummer H1 ALPHA
    Ford guy turned GM
    State College, PA
    3,552
    havent called a professional yet but will probably end up doing that real soon.
    And clark, its not a plasma, its a DLP TV which is made up of thousands of those tiny mirrors.
    I was doing some reading, either its dirty back there on the light engine part of it, which consists of the bulb, color wheel, and some other things
    or one of those tiny mirrors is stuck open.. Also read that if that is the case, then the entire mirror assembly thing needs replaced which is expensive. kinda sucks.
    anyone else ever run into this problem?
    2013 Mustang GT
    1999 Contour SVT
    Senior Member Jper's Avatar
    Monessen
    1,366
    IS it a dead pixel?
    2007 Civic SI fo do.
    i-VTEC...Do you?
    Josh
    pa
    860
    Unscrew all the screws on the back side, the ones that go around the out side of the tv. Think there is like 16 or more. The front screen will come off or slide out. KEEP it facing the same way it came out so it goes back in the same way. Clean them and the mirrors in it with a micro fiber towel and auto glass cleaner. NO ammonia in it, It streaks. Put it all back together and see if that does it. OH while you have it out, pull the bulb out and do not touch it! if you do, clean it with alcohol or it will blow. Blow the fans out from all the dust so it can keep the bulb cool.. Good luck with it..
    pa
    860
    Quote Originally Posted by Jper View Post
    IS it a dead pixel?
    NO, it's a DLP TV, they don't make them any more.. Flat screens don't get hardly one pixel that goes bad, it normally one row that goes. (the line from side to side or top to bottom.)
    Monessen
    1,366
    Gotcha. Didnt knw that. TV's arent my specialty haha.
    i-VTEC...Do you?
    Josh
    out in the woods
    4,948
    use a black marker and color the screen over the white spot. fixed!!
    hahaha just kidding, i'd say something inside reflecting??
    Oct 2007
    3,125
    http://deadpixelstares.ytmnd.com/
    I dunno, good luck finding/fixing it
    pa
    860
    State College, PA
    3,552
    thanks for the suggestions guys...
    twin90GT i dont really feel to comfortable opening the TV up myself. i dont wanna screw something up haha and its pretty big (61 inch) so i dont wanna take off that big ass screen lol. im pretty sure one of the little mirrors is messed up
    2013 Mustang GT
    1999 Contour SVT
    2,145
    The DMD (Digital Micromirror Device) is the actual chip itself and sounds like it went bad. It contains roughly 921,600 micro-mirrors that make up the picture on the TV.
    Take a quick look around the net and see if they have a recall.
    Stock 03 Cobra Vroom Vroom!!
    State College, PA
    3,552
    thats exactly what ive been reading ill have to check about the recalls cause apparently there are a LOT of samsung dlp owners who have this problem and from other pictures ive been seeing, i am very fortunate to have only one small spot. I see a lot of people that have many more dots than me!
    2013 Mustang GT
    1999 Contour SVT
    Jan 2008
    181
    did you try what I said after you left my house cuz
    2007 Hummer H2
    Ford guy turned GM
    State College, PA
    3,552
    Quote Originally Posted by SUPERDUTY View Post
    what did you tell me to try? i dont remember this lol
    2013 Mustang GT
    1999 Contour SVT
    Sep 2007
    176
    Theres just a big mirror back there. I had a Mitsubishi that was getting all these red and green splotches all over and it ended up being the light engine (it was DLP also). I would open it up, carefully remove the mirror and look for anything on the back side of the screen.
    Camal Clutch
    Aug 2008
    South Hills
    80
    flux capacitor?
  1. whats up guys
    By Climb385 in forum Welcome New Members
    Last Post: 07-24-2010, 09:11 AM
  2. whats wrong with this pic??
    By Rodeheaver's in forum Pictures & Videos
    Last Post: 11-09-2008, 11:54 AM
  3. well, i found out whats wrong with my car
    By thehill63 in forum General Tech
    Last Post: 05-19-2008, 09:18 PM
  4. Whats wrong with this ad?
    By One Sweet Day in forum The Bar
    Last Post: 07-30-2007, 05:17 PM
  5. whats wrong with this pic
    By J-rod in forum The Bar
    Last Post: 06-22-2007, 02:10 PM
