Results 1 to 18 of 18
Thread: New engine
    Jun 2007
    N. Huntingdon
    1,596
    New engine
    Forged 6-bolt Crank
    Forged H-Beam Rods
    Forged 18cc Pistons
    CNC Ported Non-PI Heads w/ Oversized valves
    CMS Stage 2 Blower Cams
    Patriot Valve Spring Kit (Titanium Retainers, New Locks, .600" lift Springs)
    Canton Windage Tray and 7 Qt. Pan
    Fully Balanced - Blueprinted - 1 yr Warranty
    Est rwhp @ 10 lbs of boost is 400-430 hp and similar tq ratings
    Helloooooo debt.
    Chris
    2016 Chevrolet Volt
    2010 Jetta TDi Cup Edition
    1964 Lincoln Continental
    Mars, PA
    1,696
    So you finally decided what to do huh. Sounds like a nice combo
    Dennis
    2006 GTO
    Gone but not forgotten
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    Jun 2007
    N. Huntingdon
    1,596
    Yea it's took me long enough.. Insurance will be too high for a C5 Corvette so I'm still a Mustang guy for now which is fine by me.
    Other than the motor, theres only two other parts i need to buy for the exterior of the car and then its done.
    Chris
    2016 Chevrolet Volt
    What's the compression ratio?
    Senior Member dpstang98gt's Avatar
    Feb 2008
    East Liverpool, Ohio
    620
    thats some good numbers for being NPI, are you going to take it to the dyno?
    1998 TT GT....
    1998 Honda Civic Stock DD
    1994 Jeep Grand Cherokee, 4 inch rough country suspension lift and BFG 32 inch M/Ts
    2000 Seadoo RX Millenium Edition 951
    Sounds cool. I don't follow the MOD motor stuff close enough, but are the ported non PI heads to keep the compression down? I seem to remeber that the PI stuff bumps the compression???
    pa
    860
    Quote Originally Posted by Mitternacht View Post
    Helloooooo debt.
    Like I say, you gotta have a goal! if not, why do anything!
    Ligonier, PA
    6,365
    wow man that sounds awesome...cant wait to see it in the spring.
    2018 Jeep Grand Cherokee
    1931 Ford Model A - Project
    1991 BMW 325iX
    1978 Ford F150
    1952 Ford F2 - Project
    Polar Vortex
    6,031
    They say the 96-98 cars end up having more comp. than the 99-04's after the pi swap.
    Jun 2007
    N. Huntingdon
    1,596
    My supercharger intake, AFAIK, only works with NPI heads. I believe with this intake on PI heads, I may have an issue with coolant pouring into cylinder 5's intake, which is no good. This is just based off what I could research online.
    However, I went with the -18cc dished pistons for in case i eventually get PI heads, and a more efficient supercharger kit, then the compression will still be in the area of 9:1 after the PI swap.
    So basically, I'm designing this motor with the future in mind and to handle the power it makes now with ease.
    I was told 487 rwhp when i bought it. Without dyno results to prove that, and a best trap of 109 it's more around dennis's guess of 340-350 rwhp. After this motor swap, it should be able to put out 400+- rwhp, and handle much much more.
    But that's the next problem, how much can a stock T-45 Transmission take!?
    Chris
    2016 Chevrolet Volt
    Feb 2008
    620
    my t-45 was holding up alright with 425 ft lbs of tq but my clutch was shot, do u still have the stock clutch? but anyway i went with Bob Hanlons upgraded t-45 this year with the 26 spline input, upgraded forks, and synchros and basically a rebuild kit, so im hoping it holds up, but we'll see
    1998 TT GT....
    Feb 2008
    620
    i was also wondering if your still using the NPI intake manifold?
    1998 TT GT....
    Jun 2007
    N. Huntingdon
    1,596
    Yea, my SC intake is going back on.
    Chris
    2016 Chevrolet Volt
    2,145
    Sounds like a nice build but why only 10lbs of boost? Is that what your supercharger is limited too?
    Stock 03 Cobra Vroom Vroom!!
    Jun 2007
    N. Huntingdon
    1,596
    I think it makes 9-10 psi. It comes with a 6lb pulley, but the gains are only 50-80hp that way. Also I've had a couple people tell me that that pulley may be over spinning the supercharger, like putting out more heat with more boost which could hurt the power output. I don't think this is that big an issue. Because of the design I cannot intercool it so I do have a Snow Performance Methanol Kit on the car to help with the heat.
    Besides, what I've got to work with is what came on the car when I bought it. When the time comes, I'll move to PI heads and a Saleen or KB Supercharger.
    Chris
    2016 Chevrolet Volt
    Jun 2007
    N. Huntingdon
    1,596
    Because I should of had this engine by now, the builder's throwing in an 8-bolt cobra crank, new aluminum flywheel and a Teksid block.
    Chris
    2016 Chevrolet Volt
    Polar Vortex
    6,031
    Hells Yeah!! Some good and bad after the z-34 huh??
    Jun 2007
    N. Huntingdon
    1,596
    Murphy's Law has been after me lately.
    Chris
    2016 Chevrolet Volt
  1. I'm looking for an engine--
    By oldfox in forum Ford Parts
    Last Post: 08-17-2011, 04:28 PM
  2. FS: 95 GT 5.0 L engine
    Last Post: 05-20-2010, 04:33 PM
  3. WTB: Engine Stand + Engine Hoist
    Last Post: 10-16-2008, 01:22 PM
  4. 5.0 engine shroud, battery tray, engine stand
    Last Post: 08-24-2008, 06:54 PM
  5. engine ?'s
    Last Post: 07-02-2008, 10:34 PM
