Results 1 to 8 of 8
Thread: somebody thinks they no but dont
    96twinturbo bill412's Avatar
    May 2008
    penn hills pa
    187
    Ok guys me and my boy are sitting here right now talking about his brothers mustang.which eaton can go on the 00-04 GT.he says its one I heard its none without the torktek kit.please help me prove him wrong unless im wrong which might be the case.I never seen his bros car so i dont know if its true.he said it off a T-bird or something.I know the roushcharger works off the same year roush,and saleen 2v
    Senior Member TJH64's Avatar
    Delmont PA
    320
    It uses the M112 off of the 03/04 Cobra.
    NEWB crusher101's Avatar
    Jun 2007
    dormont
    613
    you can use the supercoupe tbird sc on them i think.
    Delmont PA
    320
    I should've been more descriptive. The Torktech kit utilizes the M112 03/04 blower for the install on 99-04 GT 2v.
    May 2008
    penn hills pa
    187
    yea the torktek does but its not a m112 so what could it be.and how would a supercoupe work are they even close
    Delmont PA
    320
    Super Coupes use the M90 blower. The most distinguishable feature of the M90 would be the discharge location is on the top of the blower housing. It is physically smaller, also, than the M112.
    It would require some major fabrication for this to work on a 4.6.
    May 2008
    penn hills pa
    187
    Ok so no eaton will work without major fab or the torktek kit
    Jan 2008
    Jefferson
    4,674
    The t-bird m90 will work on a 4.6. Just ask mitternach. He has one on his car
    Atleast I'm pretty sure its a m90
    here ya go... anything is possible
  1. this guy i know thinks he has 750 hp
    By blaze00 in forum The Bar
    Last Post: 01-06-2010, 10:59 AM
  2. She thinks my tractor's sexy
    Last Post: 03-21-2009, 06:02 PM
  3. Shhhhh, dont tell anyone.......
    Last Post: 09-11-2008, 12:45 AM
  4. dont miss me too much today
    By J-rod in forum The Bar
    Last Post: 06-05-2007, 02:09 PM
  5. lights dont work
    By static-x in forum General Tech
    Last Post: 05-11-2007, 12:33 PM
