I am going to most likely tear my engine down and rebuild it.
It is almost (if not completely) stock. Now I have heard the 94/95 Mustangs were persnickety about mods and the Cobra computers were even worse.
But I will have the engine torn down. So with keeping the Cobra intake, and ECU, what can I do to upgrade and still keep it running.
Will a CR increase cause a problem?
Will a different cam work much better then the stock?
Swap heads for a set of AFR 185? (this also forces a piston swap because of valve size)
I am not looking to swap a A9L and install a MSD. Not a stroker either, I hear it causes the computer to barf.
I understand the FOXs are so much easier to mod...
