Results 1 to 6 of 6
Thread: battery
    Kittanning,Pa
    224
    battery
    Hi guys got a question I have my battery in the trunk of my car due to no room with supercharger will this make it harder to start the temp here is 20 degrees the guy I bought it from said click the key on but don't start hold there for 20 sec then turn back off then push to start. Should I try and fit it back to the front of the car
    Thanks bryan
    do you have a push start? and I wouldn'y think so man. And 20 secs!? lol what year is your car? A OBDII car think 30,000 times a second. if ANYTHING just turn the key to run and wait like 1 sec. then start. to just get the fuel lines pressurized. but not all that important. i think your good. the battery just starts the car and thats it.(unless you turn car off and have radio on)
    hopes this helps and goodluck
    Kittanning,Pa
    224
    I was told the battery don't have enough cranking amps when it is cold out when warm fires right up
    Bryan
    Nov 2008
    ELIZABETH TWP.
    885
    just get a bigger battery with more cca will work fine
    who said that
    Uniontown
    1,792
    Also get some good cable. That silly shit they sell with those cheap ass relocating kits is thin and doesnt really carry the current well. Also remember it gets heated by the motor. I would suggest some nice heavy cable and a red or yellow top battery.
    Got Smoke?
  1. Battery recommendations
    By Killercanary in forum The Bar
    Last Post: 03-13-2011, 03:22 PM
  2. Battery Light?
    By thaley21 in forum General Tech
    Last Post: 03-06-2011, 03:51 PM
  3. Battery Shut Off
    By Stangman701 in forum Drag Racing
    Last Post: 09-02-2010, 04:46 PM
  4. spark from battery!!!
    Last Post: 02-09-2008, 05:51 PM
  5. Battery on/off switch
    Last Post: 04-25-2007, 09:40 AM
