Results 1 to 3 of 3
Thread: clutch start question
    Jan 2008
    Jefferson
    4,674
    last summer i did a auto to manual swap. everything is fine except you dont have to push the clutch in to start it. i have a auto wiring harness on now with the park/neutral safty switch on so it will start. my question is does anybody know how i can wire it up so i have to push the clutch in to start it. i pluged all the wires in under the dash but not sure what is what.
    1,220
    If it's the same as a Fox there are 2 different jumper harnesses off the main wiring harness. One for a stick and one for an automatic. If you get the stick harness everything should work fine. Do you have reverse lights now? On the Fox there are some shunts that need removed or installed. I can't remember. It's easy to switch out the harness. If you don't want to do that just install a clutch switch and jumper the neutral safety switch wires to it.
    Jan 2008
    Jefferson
    4,674
    yes there are 2 harnesses under the dah but i only have one 1 pluged in i dont know where the other is. i have reverse lights since i jumped the auto harness.
    so with the manual trans harness ill be fine??
  1. Clutch fork question
    Last Post: 12-01-2012, 09:42 PM
  2. Clutch Question
    By MAXXIS828 in forum General Tech
    Last Post: 02-16-2011, 11:44 PM
  3. 85 T-5 Clutch Question
    By TheGreatWhite in forum Fox-SN95
    Last Post: 10-25-2008, 02:09 PM
  4. clutch question
    By 85stang in forum Fox-SN95
    Last Post: 02-24-2008, 12:14 PM
  5. Clutch question??
    By mineralrob in forum S197
    Last Post: 12-24-2007, 04:10 PM
