Results 21 to 40 of 45
Thread: bought a KB
  1. #21
    SLOW
    Greensburg
    335
    Congrats. The 2.2 definitely wakes the car up
    04 KB Cobra
    2008 Jet Steam Blue Z06
  2. #22
    BUTLER,PA
    161
    I am thinking of installing my KB, injectors, MAF and BAP myself. I do not have much experience working on engines, but I am a smart guy with a basic understanding of how our engine works. what do you guys think? Also if I do the installation myself will it be safe to drive to a tuner as long as I don't boost?
    '04 Black Cobra Coupe
    2.2 Kenne Bell, FIPK, Accufab TB and Plenum, Bassani catted X, Borla catback, Head Cooling Mod, LFP HE, SCT custom tune by Terry@Street Lethal Performance
    Complete IRS bushing kit, FLSFC's, BF IRS Brace and Brackets, MM adj tie rod kit, MM aluminum steering rack bushings, Fiore quadrant and ADJ, MGW shifter
  3. #23
    KB snake
    Jul 2008
    altoona pa
    527
    the install is fairly simple if you follow the step by step instructions and have all the tolls needed. make sure when you do the boost a pump you do the wire mod. its worth it. I aint so sure if you will be able to drive the car to the tuner for the simple fact you are going to have alot more injector though. might be best to just find a buddy to give you a tow.
  4. #24
    2,145
    Let me know if you need help I can lend a hand. I have not done the swap on my car yet but I plan to , if I go this route, and have done allot of reading on it.
    I would not drive the car to the tuner with all the mods done on the factory tune. You are going to foul the plugs in no time with the 60lbs injectors. You should have two options. The tuner may be able to e-mail you a better tune to get you to the shop (staying off the boost) or maybe you could leave the factory injectors and maf installed (staying off the boost) and swap them out at the shop.
    Or have it flatbedded out. Heck you can rent a trailor if you have a truck.
    Stock 03 Cobra Vroom Vroom!!
  5. #25
    BUTLER,PA
    161
    Thanks a million for the offer. I just may take you up on that. Where did you get research material on the swap? Just off the net? I have AAA Gold, so i will just have it flatbedded
  6. #26
    2,145
    I found a video of the swap proccess on the net. I will look for it when I get home. It wasnt bad at all. The only warning I read was to heat up the bolts that hold the intercooler to the blower so you dont risk snaping one off.
  7. #27
    KB snake
    Jul 2008
    altoona pa
    527
    If you write kenne bell an email they will send you the instructions to do the swap.
  8. #28
    BUTLER,PA
    161
    Thanks! I will do that
  9. #29
    2,145
    The following is a list of info that might help you. I will be making additions as I find time today.
    KB '03-'04 COBRA TECH & TUNING TIPShttp://www.kennebell.net/techinfo/fo...00techtips.pdf
    Belt Selection Guide
    http://www.stangshiftergaskets.com/b...tion_guide.htm
    Mag test/info
    http://www.mustang50magazine.com/tec...ll_blower.html
  10. #30
    BUTLER,PA
    161
    Mag test/info
    Sweet! thank you so much for the help!
  11. #31
    KB snake
    Jul 2008
    altoona pa
    527
    also forgot to add not sure how much boost you plan on running but i would get a nice set of idlers to eliminate belt slip. i have the ones from lfp and they are really nice. I am also running a reichard racing upper pulley. great piece and never had any belt slip at all running 19#s
  12. #32
    BUTLER,PA
    161
    Apparently it has a 2.8 pulley on it. How much boost will that make with the stock lower? I want to make 17lbs
  13. #33
    KB snake
    Jul 2008
    altoona pa
    527
    3.0 makes 17#s with stalk lower. 2.75 makes 19# with stock lower. so you will be right around where you want to be. make sure you buy an idler set. if not at that kinda boost you will have belt slip. its also going to live on 93 octane for sure and need a really good tune in it
  14. #34
    2,145
    Here is the video of the eaton removal.
    [ame="http://vimeo.com/2011187"]Eaton Removal on Vimeo[/ame]
    PPRV Delete for Dummies - Step by Step
    [ame="http://vimeo.com/2134128"]PPRV Delete for Dummies - Step by Step on Vimeo[/ame]
    Kenne Bell Pulley / Boost / Ratio
    http://www.kennebell.net/techinfo/fo...ulleyRatio.pdf
    KB Mammoth ;)
    http://www.kennebell.net/techinfo/fo...TH_03cobra.pdf
  15. #35
    BUTLER,PA
    161
    Thanks so much guys! Very cool!!!! I already have an idler set with the extra aux idler...
  16. #36
    KB snake
    Jul 2008
    altoona pa
    527
    anytime man, you got any questions feel free to pm me. wait till you get it all done, its going to scream. you should be right around the 600hp mark. damn now i miss my car and want summer here lol
  17. #37
    fairmont,WV
    1,352
    ive installed a couple KB's. If you buy beer and food, I might just be persuaded to drive up and help.
    XXX RWHP
    XXX RWTQ
  18. #38
    BUTLER,PA
    161
    Thanks so much for the offer man! just may take you up on that. I was thinking early Spring, so I have a bit.
  19. #39
    BUTLER,PA
    161
    Who makes KB upper pulleys? Metco says they do not
  20. #40
    KB snake
    Jul 2008
    altoona pa
    527
    I am running a reichard racing upper and love it. great quality piece. I forget who but one of the sponsers on here said they just started selling there stuff. If you wanna make 17#s just get a 3.00 upper and leave the lower alone.
  1. Bought a Whipple for the 11
    By jaa55 in forum S197
    Last Post: 03-24-2011, 01:02 PM
  2. Bought a new car
    Last Post: 01-24-2011, 10:43 PM
  3. Well... I bought a GM
    By Stangman701 in forum Pictures & Videos
    Last Post: 10-08-2010, 11:04 AM
  4. Just Bought!!!
    By How Much? in forum The Bar
    Last Post: 04-22-2008, 10:58 PM
  5. Bought an AK-47
    By PHFIRENO7783 in forum Pictures & Videos
    Last Post: 10-22-2006, 10:48 PM
