SWEET! What size AR turbine housing will you be running?
Damn dude nice work now make with some pics quick!
Mike
sounds like a sweet project.. gotta love TTs
850 hp... Is that enough John? Holy sh#t... You better update your life insurance.. There won't be much around that will touch you in a race. Can't wait to see it![]()
17 Ram 1500 Big Horn Hemi
16 Comp O GT Performance Pack
I'm running a 28" tire as well. I went with a set of 3:31 gears out of a 05+ Mustang. You can pick them up very reasonable cause they are the stock gear and there is only a difference of about 1-1/2 mph on the top end of 4th gear (150mph vs 151.5) as compared to a 3:27 gear.
nice can't wait for more updates
Just another update: we decided to go with 60mm turbos because with 57's I'd be limited to 1000 fwhp, any more than that the turbos will be out of the efficiency range. With the 60's I'll be able to make 1000 rwhp and stay within the turbos efficiency range and will be able to upgrade to make more hp. I should hopefully have the car up and running by the end of april or early part of may. So look out all you hot rodders in the area for the yellow jet plane that will be running around the area.
General Douglas McArthur
Man that thing will fly for sure![]()
00 Yamaha V Star 1100
88 Ford F250
Just another update as we decided to go back to the original plan and use twin 61mm turbos. This will be capable of 1200+HP with no problem. The turbos will be in soon and will post up some pics real soon also![]()
When's the update for 2500hp comin??![]()
-Bob
95 Mustang GT - Bullit suspension, MGW Shifter, O/R X, MSD Blaster coil, Livewires, 17X9 A.R. Rebels, SS inserts FOR SALE!
