1. 88 5.0 HO COMPLETE 48K MI $500.00 1. 85 5.0 HO CARB TO PAN W/ACC. 69K MI $450.00 1.COMPLETE 5.0 94-95 T-5 W/BELL&FORK 39K MI $450.00 1.COMPLETE 5.0 HO FROM 93 T-BIRD $300.00 1. 89 5.0 HO COMPLETE DISASSEMBLED $300.00 1. COMPLETE FRESH 8.8 4.10 W/H-D 4BOLT AXLES $375.00 1. SET OF FORD MOTORSPORT 8.8 31 SPLINE 5BOLT AXLES NEW IN BOX W/STUDS $350.00 1.ORIGINAL 93 COBRA UPPER & LOWER INTAKE W/BBK 65MM T-B $350.00 1. USED 8.8 4.10 4BOLT REAR $275.001.SET OF NEW IN BOX UPPER&LOWER W/FITTINGS SOUTH SIDE MACHINE BARS $250.00 1.8.8 AUBURN L/W 31 SPLINE FULL SPOOL NEW IN BOX $200.00 1.SET OF 4 DRAG LAUNCH SPRINGS BRAND NEW W/AIRBAG $175.00 1. SET OF 4 USED EIBACH 1.5 LOWERING SPRINGS $150.00 1.USED 5.0 HO AOD-E $150.00 1.FORD MOTORSPORT 4.10 RING&PINION NEW IN BOX $150.00 1. FORD MOTORSPORT 5.0 ALUMINUM RAD. USED $150.00 1.93 COUPE COMPLETE LIKE NEW A/C-HEATER SYSTEM $150.00 1.SET USED 70/30 LAKEWOOD STRUTS-50/50 SHOCKS $150.00 1.FORD MOTORSPORT ALUMINUM DRIVESHAFT $150.00 1.POLISHED 70MM T-B &SPACER $150.00 1.POLISHED 65MM T-B &SPACER $140.00 1.FORD RACING MATCHED SET 24LBS.INJECTORS $125.00 1.C&L 73MM MASS AIR METER FOR 24LBS. INJ.$125.00 1.92 T-5 TRANNY NEEDS SYNCRO'S $125.00 1.TURBO COUPE T-5 NO-REVERSE $120.00 1.NEW IN BOX FLOWTECH FULL LENGTH 1 5/8 HEADERS $115.00 1. MATCHING H-PIPE 2 1/2 NEW $155.00 1.HOLLEY 190GPH PUMP NEW IN BOX $100.00 1.87 SPEED DENSITY PCM $100.00 1.ELDEBROCK PERFORMER 351W 2181 ALUMINUM INTAKE $110.00 1.SET AGX ADJUSTABLE USED STRUTS $125.00 1.SET USED SOUTH SIDE LOWERS $85.00 1.USED 87-93 HOOD $75.00 1.LIKE NEW SOUND DEADNER&INSULATION OUT OF 93 COUPE $50.00 1.93 A4LD SHIFTER $25.00 1.93 4CYL AUTO PCM W/CONNECTOR $25.00 1.GT-40 1"SPACER W/BOLTS $25.00 1.GT-40 1/2" SPACER W/BOLTS $25.00 1.GT-40 1"SPACER $20.00 AND MUCH MUCH MORE CALL DAVE (724)425-1911 UNIONTOWN,PA.SAVE MONEY,MONEY! SAVE MONEY,MONEY!
