Results 1 to 15 of 15
Thread: car will run fien then just shuts off
    Feb 2009
    Latrobe
    517
    hey guys i went up and got a new tfi module harness from lou today hoping it was the problem but it didn't fix the problem
    my 90 lx is running fine then it will all of a sudden just shut off like i turn a switch
    it will start back up though but will then shut off after ten to fifteen seconds then let it cool back down and it will run fine for a while then act up again any suggestions
    i have replaced the pickup coil inside the msd distributor, the harness for the tfi, tested the msd and coil, new tps, and new idle air, cleaned all grounds
    this is the first time i have needed help and any would be greatly appreciated
    PROBE PISTONS
    PROBE BILLET I BEAM
    super victor
    230cc CNC
    Hooker 2 in headers
    pa sc c4, 4600 stall
    9" LADDER 3.70 PRO GEARS
    SW BACKHALF
    moser 35 SPLINE axles
    1050 RACE DOMINATOR DEMON
    250 FOGGER KIT
    snow performance stage 2
    1.316 60ft 9.16@156
    Quote Originally Posted by 90TitaniumStang View Post
    I did not see the TFI module itself on this list??? The only way they will show up as bad in testing is for them to be in a failed condition )and it isnt when it cools down). Sounds like classic TFI that it runs when cooled off.
    State College, PA
    3,552
    i agree with above post, its most likely the module itself, not the harness
    2013 Mustang GT
    1999 Contour SVT
    1,220
    If its not the TFI module try the EEC relay and the fuel pump relay too.
    Feb 2009
    Latrobe
    517
    i did the module im sorry i thought i put it on there where is the eec relay
    PROBE PISTONS
    PROBE BILLET I BEAM
    super victor
    230cc CNC
    Hooker 2 in headers
    SW BACKHALF
    250 FOGGER KIT
    1.316 60ft 9.16@156
    May 2008
    Pittsburgh
    229
    either the module itself is bad or it could be the fuel pump tony71502 on here had that same problem with his car u could try and pm c what he says. i know he changed the fuel pump and fuel filter. hasn't had a problem since
    01' Gt=
    87' Notchback 5.0 =
    May 2008
    Pittsburgh
    229
    never mind on the module lol
    01' Gt=
    87' Notchback 5.0 =
    1,220
    I can check at work tommorow at work. I think it is above or near the PCM, but I will check.
    Ligonier, PA
    6,365
    just throw a JAP motor in it.
    2018 Jeep Grand Cherokee
    1931 Ford Model A - Project
    1991 BMW 325iX
    1978 Ford F150
    1952 Ford F2 - Project
    Feb 2009
    Latrobe
    517
    the fuel pressure is staying constant i just put a computer in it and it has run for 20 minutes no and hasn't shut off the eec relay isn't under the kick panel i took the dash loose even and its no where to be found
    PROBE PISTONS
    PROBE BILLET I BEAM
    super victor
    230cc CNC
    Hooker 2 in headers
    SW BACKHALF
    250 FOGGER KIT
    1.316 60ft 9.16@156
    Feb 2009
    Manassas, VA
    46
    I have had the same problem...
    fuel pump when get hot.
    Feb 2009
    Manassas, VA
    46
    relay is under driver seat that year
    Member silvernotch's Avatar
    Bethel Park
    664
    eec relay is up by the computer behind glove box. when that goes bad you get no spark,no fuel pump.I carry an extra one with me when I have the car out.Ya never know?
    Jun 2008
    Bell Acres
    469
    As DMmustangLX said, I'm willing to bet it's your fuel pump. The pump will operate normally until it overheats and then it will shut off... In which case you will have to wait a few minutes until it cools down and starts functioning normally again. The problem with fox fuel pumps is they rely on the fuel to cool the pump, so if you consistently run a low fuel level you will overheat the pump.
    Feb 2009
    Latrobe
    517
    it was the computer
    PROBE PISTONS
    PROBE BILLET I BEAM
    super victor
    230cc CNC
    Hooker 2 in headers
    SW BACKHALF
    250 FOGGER KIT
    1.316 60ft 9.16@156
  1. What motor oil do you run in your car?
    By ModularMike in forum The Bar
    Last Post: 08-04-2011, 06:22 PM
  2. Car won't run.....
    By Viper_ed in forum Wolfpack Speed
    Last Post: 08-20-2010, 01:38 PM
  3. Replies: 9
    Last Post: 11-16-2009, 06:44 PM
  4. Run your car on water..
    By Jper in forum The Bar
    Last Post: 11-05-2008, 04:50 PM
  5. Headed to Beaver Run on Thursday, which car to take???
    By Killercanary in forum Autocross & Road Racing
    Last Post: 11-08-2007, 12:27 PM
