Results 1 to 20 of 38
Thread: GT40 heads
    GT40 heads
    As the title says looking for a pair of GT40 heads. Prefer non P heads but let me know if you have any for sale.
    Also did these heads come on anything other than cobra's and v8 explorers?
    They also came from the 1st gen lightning and the '95 Cobra R. After 97-1/2 the explorers and mercury mountaineers had the GT40P's. If I had to choose between the two I'd run the GT40P's personally.
    Here's some GT40's for sale:
    http://www.superstallions.com/forum/tm.aspx?m=158401
    I'd run the p's also but i've read you need special headers for them. What will work with the p heads?
    Sep 2007
    Dayton PA
    3,795
    I used FMS shortys, all fords headers are made to work with the Ps now. i think any long tube will get the job done. i also have a set of equal lengths that look like they might have worked but they were getting thin so i didnt bother trying them
    03 Torch Red Anni. Ed. Cobra
    01 cobra: traded
    93 LX Modular 4v swap
    State College, PA
    3,552
    Quote Originally Posted by sinful rides View Post
    im using mac shorties with mine but i had to pound the #3 and #7 (i think) tubes just slightly so i could get the plug boots on. also had to use wires with 90 degree boots.
    your best bet is to use fms shorties, i hear nothing but good things about them with P heads.
    here is everything you'll need to know: http://forums.corral.net/forums/show....php?t=1014187
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Senior Member TJH64's Avatar
    Delmont PA
    320
    Are you planning on using these heads on the 408 you are planning to build, which you alluded to in your other thread??
    Fordstrokers 347 4.030 bore, 3.400 stroke, 5.315 rod, 10.6:1CR
    Canfield 195 heads, Ferrea 6000 valves, Comp springs, Ti retainers, roller rockers, hand bowl blended
    Camshaft Innovations custom billet core hydraulic roller camshaft
    TFS Track Heat, 75mm TB, 90mm MAF, 36lb/hr inj
    TREMEC 3550, billet flywheel, RAM clutch, 4.10 gears
    Thats what I was planning with a port and polish and bigger valves. Am I making a bad choice with these?
    State College, PA
    3,552
    putting them on a 408!?
    dont do it!
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    What heads would you guys recomend. I had Trick Flows and they broke on me. I'd like to stay with irons with a 61cc chamber or bigger. Also I'll be running boost also.
    My only choice for an engine that large would be a set of AFR 205/225's. Why stick with Iron, especially if your putting a heavier windsor block up front and a heavy supercharger? Aluminum can be repaired too if something goes bad.
    Gt40's on that setup... YIKES! That's not a good idea.
    train kept a rollin! thebreeze72's Avatar
    Jun 2008
    u-town
    343
    Cool I Got What You Need!
    I HAVE A PERFECT INEXSPENSIVE IRON HEAD FOR YOUR 408 ! I HAVE A SET OF COMPLETE N351 CAST IRON FORD MOTORSPORT HEADS THAT ARE MILDLY PORTED AND CUT TO 60CC CHAMBER S/S 2.02X1.60 VALVES ALSO A SET OF 1.6 YELLA TERRA SHAFT ROCKERS LIKE NEW $1200.00 TAKES EVERYTHING MAYBE GOOD SET OF PUSHRODS ETC. ALSO BUT I DON'T KNOW YOUR COMBO ! IF YOU WANT ALUMINUM HEADS HOW ABOUT A SET OF BRODIX TRACK 1'S SET UP FOR MECH. ROLLER 2.08X1.60 S/S VALVES .700 LIFT SPRINGS 54CC CHAMBERS AND W/ T&D 1.7 SHAFT MOUNT ROCKERS AS IS $1200.00 CALL DAVE 724-880-4580
    x2 on the afr's
    State College, PA
    3,552
    get some AFR 225's
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Head comparison
    I did a comparison against a few heads. Trickflow Brodix AFR Dart and Racing Head Service on Summits site. I first threw out Trickflow and Dart because of price. The Brodix heads seam to be the smallest of the heads and $1600. So RHS is 10cc smaller on the intake 14cc smaller on exhaust and a smaller valve lift of .550 to .700. The RHS is avaliable in iron at $1080 and aluminum at $1380. The AFR's are larger but are they worth $460 more than the aluminum RHS heads.
    I tried to make a link to the comparison but it didn't work.
    Also any guess as to power I'll make? Considering buying a sportsman block if the foctory will break>
    What is your budget and goals?
    I don't want to spend more than $4K. Car will mostly be street driven with a few passes down the 1/4. I'd like to stay with a factory block to keep cost down. I've heard 351's are good to 700hp. I'm only looking to make 500-600hp if the stock block can take it. I plan on using Eagle forged stroker kit with 28cc dish and Jay Allen cam.
    State College, PA
    3,552
    you should be fine with a stock 351 block, they are very strong (at least compared to the 302)
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Got Boost?
    West Mifflin
    1,442
    Im going to be running the new Trick Flwo Fast As cast heads on my 408W. Very reasonable price for the performance. $1600 assembeled i believe.
    2013 Race Red F-150 Screw FX4 Ecoboost
    1994 Rio Red GT
    10.60 @122.88
    Sold
    Big Daddy gmkillr's Avatar
    At the racetrack
    4,193
    I would talk to Jay Allen and follow his recomendation for heads.
    Corvette Z06
    Senior Member DMmustangLX's Avatar
    May 2008
    Pittsburgh
    229
    Quote Originally Posted by Killercanary View Post
    x2 gt40's on 408 AFR's will be ur best bet for what u want to do
    01' Gt=
    Mac 2.5 in. prochamber with high flow cats, mac exhaust, steeda strut tower brace and bbk alum. underdrive pullies and more to come
    87' Notchback 5.0 =
    3.55's, rebuilt t-5, upper and lower control arms, steeda subframes, torque box reinforcements, mac girdle, s.s brake lines, b.s flywheel, ram hd powergrip clutch, steeda adj. clutch cable kit, steeda tri-ax and way to much other stuff to list
  1. GT40 3 bar iron heads,NOT P HEADS!
    By 1badnotch in forum Ford Vehicles
    Last Post: 07-05-2014, 03:14 PM
  2. Looking for GT40 Heads
    By Black87GT in forum Ford Parts
    Last Post: 03-23-2012, 08:24 AM
  3. gt40 heads
    By 89stang in forum Ford Parts
    Last Post: 06-25-2010, 09:10 PM
  4. GT40 Heads
    By ruger77 in forum Ford Parts
    Last Post: 01-30-2010, 05:30 PM
  5. Look Gt40 Heads!!!!!!!!!!
    Last Post: 08-19-2009, 10:25 PM
