View Poll Results: Trick flow TW or AFR???
Voters
26. You may not vote on this poll
  • Trick flow's
    14 53.85%
  • AFR's
    12 46.15%
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: Trick Flow TW heads Vs AFR's???
    Polar Vortex
    6,031
    Alright, looking through the gt 40 heads thread I figured this would become a decent conversation and not clutter it up with off topic talk, So??
    Which do you like and why?
    Turbo Trans Am=WEAKSAUCE
    Dec 2008
    Elizabeth, PA
    32
    neitheer. brodix!
    978
    I think everyone should run the gt-40's
    Uniontown
    1,792
    High ports more bang for the buck.
    Got Smoke?
    Esslinger ARCA head :D
    Dec 2008
    Elizabeth, PA
    32
    sounds like some honda 4 pot head
    978
    Quote Originally Posted by HidalgoGT View Post
    You know it! I know of a 438 c.i. with 225 high ports making over 600 RWHP on 87 pump gas. It is a carbed road race car.
    Uniontown
    1,792
    Pretty much what i am going with and supposed to put out like numbers maybe a lil more
    Got Smoke?
    978
    Should be one hell of a runner!
    Senior Member TJH64's Avatar
    Delmont PA
    320
    I'm partial to the Canfields myself; 20*, 195 head with .400" raised exhaust ports, 2.06" intake valve, 1.60" exhaust. These things make great power, but fly under the radar, as they do not have the marketing that AFR or Trickflow has.
    how bout patriots?
    Polar Vortex
    6,031
    Always a smartass...
    I have the street heat kit from trick flow. I like it but I'm never happy with the horsepower in my car.
    Petersburg,PA. 16669
    816
    both good heads.I've been a trick flow man for years but bought a set of AFR 205's for this 347 and they seem to work great
    All depends also in what you are building.If you are gonna get crazy and build a 400+ cube motor I would get ported high ports.OTS shelf high ports aren't very good but you port them and there isn't much that will beat them
    I think that if you are looking at a twisted wedge head OTS or a AFR 185 I'd go 185
    88 GT...and some boost
    Belle Vernon
    1,294
    Like someone said above it depends what you are building because bigger isn't always better. If you are comparing Trick flow and AFR, you have to compare the twisted wedge that are CNC and the AFR 205's. I think they are so close it probably doesn't matter. I have a OTS twisted wedge non CNC just casted because they didn't have the CNC option yet and the car runs 11 teens on the motor. You could probably say that im happy with them. I would take either one CNC over a casted head any day.
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
    If you like replacing valve guides, go with AFR, if not, get TW's.
    Greensburg
    843
    SECOND THAT!! ha
    -Frank-
    1986 GT-- HCI
    2011 WRX
    1999 B2500 7.5/9 drop
    ruffsdale
    3,625
    Stock heads FTW!
    2013 Mustang Gt GHIG
    1978 F150 Camper Special
    1999 Harley softail
    1998 Buell Thunderbolt
    1997 Buell Thunderbolt
    Polar Vortex
    6,031
    Stock heads FTW!
    You're gonna rip mikes rollers from the ground on dyno day.
  1. trick flow R heads
    By wick in forum Ford Vehicles
    Last Post: 09-03-2012, 06:39 PM
  2. Trick flow heads
    By sinful rides in forum Ford Vehicles
    Last Post: 01-03-2009, 09:44 PM
  3. Trick Flow heads for 2v
    By Ares in forum SN95-New Edge
    Last Post: 12-24-2008, 08:30 AM
  4. WTB AFR or Trick Flow
    By 393rag in forum Ford Parts
    Last Post: 03-18-2008, 09:33 AM
  5. Trick Flow TW heads/intake ?
    By 93Cobra5.0 in forum Fox-SN95
    Last Post: 03-15-2007, 07:45 PM
