Results 1 to 10 of 10
Thread: 03 cobra transmission removal
    Corvette Killer xxtorinoxx's Avatar
    East Liverpool, OH / Butler,PA
    14
    I haven't posted on here for a while but it is good to be back,
    I have to have my t-56 rebuilt due to a bad syncronizer and possibly a bent shift rod. I am going to remove the transmission at home and take it to a friend to do the work.
    My question is where am i going to run into problems with removing the transmission?
    Is it worth it to install a 26 spline input shaft??
    Whats the best clutch to go with if it needs replaced also??
    Also its nice to see some more terminators in Butler.
    ____________________________
    2003 Mustang Cobra
    2.76/4lb lower
    499 rwhp @ 5750 rpm
    538 ftlbs @3500 rpm
    Best E.T 12.099 @ 116.5 mph
    60ft 1.68
    1968 Ford Torino
    460 CI Big Block
    Best E.T. 13.08 @ 106.1 mph
    60ft 1.94
    Senior Member dpstang98gt's Avatar
    Feb 2008
    East Liverpool, Ohio
    620
    hey whats up man i also live in East Liverpool i never seen your car around?
    but if you got the cash to go with a 26 spline input it would be a good idea, definately a weak spot on the t-56
    i went with a dual friction centerforce clutch, but heard RAM was also a good clutch
    1998 TT GT....
    1998 Honda Civic Stock DD
    1994 Jeep Grand Cherokee, 4 inch rough country suspension lift and BFG 32 inch M/Ts
    2000 Seadoo RX Millenium Edition 951
    2.4 KB & Juice
    Export, PA
    844
    I'd say the spline depends your future with the car. You plan on heavier "go fast" mods, alot of racing? etc etc
    I did one on mine when I did my motor, but only because it was out of the car and figured what the heck. I had 33k hard miles on my stock input shaft, never had an issue. As well has many others have broke them doing less.
    As dpstang said, RAM is the way to go. I got my RAM Powergrips from Lou, always great prices. and awesome clutches!!! If you keep the aluminum flywheel, u will see some chatter with the ram, but it's easy to get used to. I eventually went to a steel flywheel, it pretty much eliminated the chatter.
    07 Silverado
    05 R6
    Sold: 03 Cobra, Built motor - 2.4 KB - N2O
    Jan 2008
    Jefferson
    4,674
    best clutch is a hard one. its all personal prefence. i have a ram hdx. i love it!! its hard but not too hard it would be great for a daily. spec clutch can be hard although ive heard plenty of bad thing about them aswell as good things too. i know spec clutchs like to chatter. centerforce is a very good brand. remember you get what you pay for and centerforce can prove that! they are expensive but prob the best clutch out there!! otherwise i say RAM FTW!!!
    you should probally have no problems removing. upgrading to 26 spline is a good idea. although i dont know much about terminators
    BUTLER,PA
    161
    Quote Originally Posted by xxtorinoxx View Post
    What's up buddy, nice ride! There are a couple guys from Butler with 03/04's on here. Don't think I have ever seen your car around. As far as the input shaft, I don't know a whole lot, but I just ordered a 26 spline. I am going to be running a KB this year though. Not sure what the stock limit is. Someone on here will give you better answers. Just wanted to say hello to a fellow Butlerite
    '04 Black Cobra Coupe
    2.2 Kenne Bell, FIPK, Accufab TB and Plenum, Bassani catted X, Borla catback, Head Cooling Mod, LFP HE, SCT custom tune by Terry@Street Lethal Performance
    Complete IRS bushing kit, FLSFC's, BF IRS Brace and Brackets, MM adj tie rod kit, MM aluminum steering rack bushings, Fiore quadrant and ADJ, MGW shifter
    14
    I dont drive it around butler too much anymore since i moved to ohio two years ago. I store the car at my dad's out there during the winter months and only get back there every two weeks or so the rest of the year.
    I probably plan on racing the car again in the future but that is still up in the air.Fiance is pretty pissed about the money i will be putting into it to fix this. Plus i should do a little more racing with my 68 torino this year anyway. I did the damage racing it at quaker city last summer and the car has been driven hard since i have owned it. I will probably upgrade to the 28 spline input shaft anyway.
    2003 Mustang Cobra
    2.76/4lb lower
    499 rwhp @ 5750 rpm
    538 ftlbs @3500 rpm
    60ft 1.68
    1968 Ford Torino
    460 CI Big Block
    60ft 1.94
    Feb 2008
    620
    do you work at Wal-Mart or somewhere else in that plaza in Calcutta? Now that i think about it, i think i seen your car parked at the end of the lot a few times
    1998 TT GT....
    2,145
    Yes but you didnt have to have the same color as mine too. Do you know how far I had to drive to get mine.
    And you have more power! Oh this is not right. lol
    Man you tricked me. So you moved from Butler? I was getting excited until I started reading. We would have had 4 cars around the Butler area. Man 4 of us ripping up main street would be more excitment then that place has seen in 20 years. lol
    Stock 03 Cobra Vroom Vroom!!
    14
    Quote Originally Posted by dpstang98gt View Post
    i do work at the wal-mart so you have seen the car up there during the summer.
    2003 Mustang Cobra
    2.76/4lb lower
    499 rwhp @ 5750 rpm
    538 ftlbs @3500 rpm
    60ft 1.68
    1968 Ford Torino
    460 CI Big Block
    60ft 1.94
    Feb 2008
    620
    ya man i always wondered whos car that was, always looked good too, but i live in calcutta on the road behind tractor supply! theres a few of us around the area that cruise up to boardman a lot u should go up sometime
    1998 TT GT....
  1. Replies: 13
    Last Post: 01-13-2014, 09:10 AM
  2. 03 Cobra Grille Removal
    By Terminated in forum SN95-New Edge
    Last Post: 09-14-2011, 01:08 PM
  3. Cobra T56 Transmission 4,900 Orig Miles!
    By Stroked03Cobra in forum Ford Vehicles
    Last Post: 12-05-2010, 06:23 PM
  4. For Sale: 96 - 98 Cobra T-45 transmission
    Last Post: 01-15-2007, 03:08 PM
