Decided to go a different route, so this has to go. This kit includes EVERYTHING you need to bolt it up and make 5-6 PSI, or change a couple things to up the boost to 8 + PSI
Price is $1450
Includes
1. Vortech/MSD Ignition Boost Controller.
2. Brand new complete oil feed kit including stainless steel S/C oil feed fitting and braided line.
3. Bosch blow off valve + hoses and plastic fitting.
4.Oil drain fitting and line with 1 extra drain line.
5. UPR power pipe
6. 2 - 3.33 pulleys and 1 smaller pulley. 2.95 or 3.13 ?? Not sure.
7. Base Vortech A trim air intake with filter and filter shield, or everything to use the UPR pipe including all rubber elbows.
8. New Autometer boost gauge.
9. 2 FMU's w/braided lines. 1 for 19# injectors, 1 for 24# injectors.
Not looking to sell in pieces. Want to sell as a complete kit. Remember, the A trim from Vortech doesn't come with 75% of the stuff listed above. You're getting everything to run at the base 5 -6 PSI + everything you need to up the boost to 8 + psi except injectors and MAF. All the small stuff adds up real quick when buying an incomplete kit. Just check the prices at Superchargersonline.com
