Page 3 of 3 FirstFirst 123
Results 41 to 57 of 57
Thread: Capri Progress
  1. #41
    Greensburg
    843
    Sweet!!
    -Frank-
    1986 GT-- HCI
    2011 WRX
    1999 B2500 7.5/9 drop
  2. #42
    let me know how that handle feels bob i been thinking of getting one for in my gt since i gotta put my seat clear back
    Got the same issue, then it's compounded by 5 point belts ;)
    I installed this today, seems fine, but is deffinately "different". Basically 1st/3rd are now where 2nd/4th where, and 2nd/4th are the whole way back.
    Shifter in 1st gear
    Shifter in 2nd gear
    Yeah, I know it's dirty.
    I also installed the new Boost gauge and changed my AEM WB02 to black face / silver bezel to match. I really like the Stewart Warner Maximum Performance gauge so far, the lighting is through the numbers versus around the bezel with an Autometer. Yeah it only idles with 10" of vacuum, price to pay for a big cam I guess.
  3. #43
    In a Time Machine
    3,361
    looks good bob
  4. #44
    Belle Vernon
    1,294
    That shifter would take some getting use to.
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
  5. #45
    Jan 2008
    Jefferson
    4,674
    ya thats weird! im think 2nd to 3rd shifts are gonna be hard to "bang"???
  6. #46
    Leechburgistain Mainland,Cuba
    1,534
    Shifter in 1st gear
    Shifter in 2nd gear
    You need a Vac storage can, check the JY for early hidden headlight cars.
    Looks like the time to make a shifter!
    289 slabside cobra
    6S1941
  7. #47
    Although the shifter looks a little strange, you need to try it. If you sit all the way back and belted in, most other styles are a bit of a reach going into third. This is actually very comfortable. We will see, I have three other type of handles here so I'll give this one a shot ;)
  8. #48
    Dec 2008
    Natrona Heights PA
    3,056
    Real nice lookin work!
    Bu-2000-bash
    ALLSQUAD
    Steel City Muscle Cars
    CarCruises
    Flashlight Drags
    NMRA
    UMTR
    Modded Mustangs
    NHSCC
  9. #49
    1,534
    I'll have to put a piece of 4x4 longways on each pedal!
    289 slabside cobra
    6S1941
  10. #50
    Member DING's Avatar
    New Bern, NC
    324
    Bob,
    The car looks great!
    You may want to consider replacing the plastice sided rad. with a solid aluminum piece. I have seem a few of those split the sides off under boost. (The water side of the block gets pressurized when a head gasket goes) Just a thought...
    Hank
  11. #51
    Quote Originally Posted by DING View Post
    Thanks Hank. Not saying it can't happen, but the failure mode on inline 2.3's is usually a little more forgiving. We either blow between cylinders (no water there) or push it out the side where it just becomes a leak. I am also running a head gasket combo that seems to let the pistons melt before it even dinks the gasket :( For sure I have thought about it and the possibilites
  12. #52
    Jan 2009
    Masontown, Pa.
    1,618
    You do great work! Talk about workmanship!! Awsome job!!
  13. #53
    Just to finish this part out (mostly), a few last pics. I fabbed up a SS heat shield for the turbine. More to keep the plug wires off the turbine that anything, but it looks okay too ;)
  14. #54
    Oct 2007
    3,125
    Sorry if I missed it but did you go with an ewg?
  15. #55
    Jan 2008
    Jefferson
    4,674
    wow that thing is clean!!! i didnt know you had a manual boost controller!
  16. #56
    Quote Originally Posted by MBH View Post
    If you External Waste Gate, no. This header is set-up so I can run one, but boost control isnt as fine at the relatively high boost we run with these things. I am using one of ATP's ultimate internal gates. I'm will to give up ultimate power if the boost is spot on for consistancy.
    I've always run a manual. I am actually replacing the one that's in the pictures. My Hallman was frigged up last fall and I borrowed Frank's Gillis. The Hallman was good to 30, the Gillis will only go to 20. New one will let me go to 50 psi if needed ;) Plus it is still a ball check type, but also has an adjustable bleed. Between te adjustable rod on the WGA, adjustable bleed, and ball check I should be able to dial the boost in pretty fine.
  17. #57
    Oct 2007
    3,125
    yeah, I meant external waste gate, sorry! I didn't remember seeing one so I had to ask. EWG's make cars sound MEAN!!
  1. Making some progress
    By Cam99 in forum Pictures & Videos
    Last Post: 02-06-2012, 08:54 PM
  2. Progress on my 01 Gt
    Last Post: 06-10-2008, 06:30 PM
  3. winter progress
    By fast4ord in forum Pictures & Videos
    Last Post: 04-06-2008, 06:06 PM
  4. Finally some progress
    Last Post: 04-07-2007, 10:08 PM
  5. Progress pics
    By fast4ord in forum Fox-SN95
    Last Post: 03-20-2007, 10:53 PM
