Results 1 to 6 of 6
Thread: Steering Shaft Rubbing LT Header
    NEWB
    Jun 2007
    Cortland, OH
    480
    I've done a little research on this and see it is relatively common. Looks like the fixes are aftermarket steering shaft and/or different motor mounts. Basically i've had the issue for a couple years since i had the lt's installed. when i turn right i can feel a slight vibration which is the steering shaft rubbing against the d.s header. I am looking to see what my options are as far as different brands that are available and what other people are using. From what i have read it seems that Ididit and Flaming River make a replacement shaft for the 99-04 cars but i don't see anything specific listed on their websites. Give me some input on what things you guys have done and give me a few different options to think about.
    Thanks
    Kerry
    1985 Mustang GT 3,100 original miles
    1985 Mustang Predator GT-302/Twister II 5S-0149 1 of 3
    Past Toys: 1964 Falcon Vert, 1966 Mustang(owned twice), 1978 Mustang II(first car), 1981 Cobra, 1982 Mustang GT T-Top, 1986 Mustang GT, 1986 Mustang GT Vert, 1987 Mustang GT, 1989 Mustang Notch, 2003 Mustang GT Roush Clone, 2006 Mustang V6(Stainless Works LT's, MBRP cat back, 3.73's, tb, cai), and my favorite 2002 Mustang GT MPH 302 stroker, KB 2.2, TKO 500 640rwhp/591torque.
    Find spot rubbing, dimple with hammer.
    NEWB
    Jun 2007
    Cortland, OH
    480
    That thought has crossed my mind, but not really the route i want to go. I know i have read several places about the rag joint on the stock shaft going bad from heat from exhaust with headers and causing the rub. I did find a couple listing on aftermarket shafts from steeda and MM. Also probably going to change mounts too, just not sure what to go with as far as brand and style(poly, solid, etc.)
    2,483
    I've shifted the engine in one of my cars, just loosened the main engine bolts, moved the engine with a jack. Sounds like its not hitting by much, could work.
    Dec 2008
    Natrona Heights PA
    3,056
    Grind some of the steering shaft away where its rubbin.
    Bu-2000-bash
    ALLSQUAD
    Steel City Muscle Cars
    CarCruises
    Flashlight Drags
    NMRA
    UMTR
    Modded Mustangs
    NHSCC
    NEWB
    Jun 2007
    Cortland, OH
    480
    Went with energy suspension poly motor mounts and a unisteer steering shaft. Have plenty of clearance now and no more rubbing issues.
  1. Flaming river 94-04 manuel steering shaft & custom column
    Last Post: 03-02-2014, 02:21 PM
  2. shorty header install rubbing
    By Darren in forum S197
    Last Post: 09-09-2012, 10:22 AM
  3. Replies: 2
    Last Post: 02-01-2012, 07:13 PM
  4. fox flaming river power steering shaft kit
    Last Post: 09-13-2010, 09:08 PM
  5. Steering shaft - FOX
    Last Post: 02-16-2010, 01:29 AM
