Results 1 to 11 of 11
Thread: PIH harness in 94 check engine light
    stuntman blksunshine88's Avatar
    Aug 2008
    duquesne
    544
    I have a 94 gt with 19lb inj gt40p heads e-cam tfs track upper/lower 70mm tbody stock mass air meter eliminated egr (installed that stupid plug thing from ebay since the resistor trick didn't work)
    I just installed a pih harness ( triple checked my wiring) with an a9l i'm getting codes for evp and something about my neutral safety switch voltage any help would be much appreciated- thanks, Greco
    -greco
    92 Coupe, 10.72@133
    Member torqueboxer's Avatar
    white oak, pa
    638
    Mike look into summit part # hly-o-85751 this should fix this problem
    Aug 2008
    duquesne
    544
    haha thanks ben no carb until 351
    -greco
    92 Coupe, 10.72@133
    Aug 2008
    duquesne
    544
    update- car idles fine with clutch pedal released, when pedal is at floor idle surges then falls off neutral safety switch differences between fox and sn95 cars?
    -greco
    92 Coupe, 10.72@133
    Aug 2008
    duquesne
    544
    no help?? paul where ya at? lol
    -greco
    92 Coupe, 10.72@133
    Greco, I wish I could help you but when it comes to the stuff you asking about I don't know the answer. I was never a fan of the PIH so I never spent any time learning about it. I don't know if there are any EEC parameters that vary based on the neutral safety switch between the A9L and the T4MO processors. I would think it'd idle better with the clutch disengaged rather than engaged just because there is a tiny amount of extra load on it when it has to spin the clutch disc and transmission input shaft, but I've never noticed a difference in either of my 94-95's.
    What is EVP? Evaporations canister?
    Aug 2008
    duquesne
    544
    exhaust valve position sensor (EVP)
    i seem to have figured this one out unplugging the clutch position switch seems to have fixed the idle problems however i'm now getting a 02 sensor code saying always lean im takin the harness back out and quadrouple checkin wiring if everything is fine welcome back T4M0! lol
    -greco
    92 Coupe, 10.72@133
    Aug 2008
    duquesne
    544
    paul EVP is EGR Position Sensor
    -greco
    92 Coupe, 10.72@133
    Aug 2008
    duquesne
    544
    had o2 signal return wire in pin 28 should have been 29 , i love the swap all driveability issues are gone!!!!! sure i left a few horses on the table but the whole swap only cost me 100bucks!! beats 350 for a tune
    -greco
    92 Coupe, 10.72@133
    Thanks Greco. I knew it couldn't be an exhaust valve position sensor as we don't have them, but the EGR makes sense. I'm glad to hear that you got it all figured out. How did you manage to do the swap so cheap?
    Aug 2008
    duquesne
    544
    ebay auction guy i didnt think id win the auction but damn if i didn't lol so whats new man
    -greco
    92 Coupe, 10.72@133
  1. check engine light??
    By 07blkfooseGT in forum S197
    Last Post: 05-14-2013, 06:58 PM
  2. 05-09 Sequential Tail light harness
    By af_one in forum Ford Vehicles
    Last Post: 07-31-2011, 09:22 AM
  3. check engine light
    By Jeep N Stang in forum The Bar
    Last Post: 09-12-2009, 04:09 PM
  4. (94-95) PIH harness with computer
    Last Post: 03-22-2008, 10:00 PM
  5. check engine light!!
    By yellowstang03 in forum The Bar
    Last Post: 03-22-2008, 11:48 AM
