i have an autometer oil psi gauge and while driving it is at 50 psi. is this a normal oil pressure? not to high or too low? my combo is in my sig...
2013 Mustang GT
1999 Contour SVT
I've got damn near the same motor set up as you, different intake and heads but relativly the same, ive got about 20k miles on my motor, on my autometer gauge i see around 75 psi at 1500rpm when cold, i run mobil1 10w30 by the way, when im at normal temp, i see 15 to 20 psi at idle 900 to 1000 rpm, if i tap the gas, to 1200 to 1500 rpm i get 50 psi and this is where i stay when warm, so id say your fine, i used to see more psi, when i had a open crankcase breather, which i found was a no no, when running a pcv valve, since i sealed the crankcase with a normal oil cap, i see the numbers i just gave you.......
306, ported and polished, edlebrock upper/lower, e303, 1.7RR's, Mass air convert, CAI, 70mm t/b, 130a 3G ALT, 1 5/8" shortys, o/r x pipe, flowmasters, subframe connectors and bracing 6pt cage, 3:73's , Sn95 5 Lug , 99 cobra wheels, full saleen kit, 2 3/4 hood..Zero Hp and Zero Tq as it sits......
