Results 1 to 7 of 7
Thread: stainless steel plates???
    In a Time Machine
    3,361
    Anyone know where I can find 1/8 stainless steel plates, I need some to make some brackets for my side skirts
    ruffsdale
    3,625
    goto Tractor supply! or gimme the sizes you need and ill look around here
    2013 Mustang Gt GHIG
    1978 F150 Camper Special
    1999 Harley softail
    1998 Buell Thunderbolt
    1997 Buell Thunderbolt
    In a Time Machine
    3,361
    not 100% sure on how big just need enough to do this
    Senior Member TJH64's Avatar
    Delmont PA
    320
    Go to Lowe's and get yourself some aluminum 1/8" x 2" flat stock. It will be way easier to bend into the desired shape and drill out.
    Jan 2008
    Jefferson
    4,674
    sand them and paint em????? thats what i would do. paint them black
    Shaler
    1,224
    The pic he posted is of mine, and they are now painted like you said.
    Mike, the size you need is about 1" wide by 1/16" thick. You can also use aluminum if you can find it cheaper than the steel, use 1/8" thick if you get aluminum though.
    Dan
    95 Rio Red Cobra Coupe
    Walking on the wild side! Shadowstealth's Avatar
    Jul 2008
    south park
    624
    ID DOO WHAT BRIAN SAID! sand and paint them flat black and inside your skirts and undercoat the underneath of your car! lol... then put silicon everywhere else... and you got your show car!
  1. Stainless Steel Systems Catback
    By Monkeygrits in forum Ford Vehicles
    Last Post: 07-07-2013, 04:49 PM
  2. F/S Flowmaster AT Axle Backs (Stainless Steel)
    By SteelTownStang in forum Ford Vehicles
    Last Post: 10-03-2010, 05:15 PM
  3. V6 Stainless Steel Tailpipes
    By pRojekt02GT in forum Ford Vehicles
    Last Post: 04-23-2010, 01:10 AM
  4. FS: stainless steel cobra inserts
    By 94svtcobra in forum Ford Vehicles
    Last Post: 07-19-2009, 05:27 PM
  5. any thoughts on stainless steel bumper inserts?
    By PunisherStang in forum S197
    Last Post: 03-02-2008, 12:17 PM
