Results 1 to 18 of 18
Thread: Battery Wont Hold Charge?
    Boat's and Hoe's fordandmopar21's Avatar
    Aug 2008
    226
    Angry Battery Wont Hold Charge?
    In my 2.3 turbo thunderbird, i was driving towards greensburg. When i left my house i noticed my lights getting dimmer and dimmer while i was driving and by the time i got near new stanton my car just died. Thanks to a few buddies of mine (Frank, Bill, and Clark ) i got it charged back up and on my way home but it did the same thing about 15 minutes later.
    Well i changed the external voltage regulator, tested the alternator which was good and it still wont run. I have a jumper pack hooked up to the battery and when the car is running as soon as i take it off it automatically dies. I even charge the battery for atleast 10-20 minutes and it still shuts off. I checked the alternator wires and they are fine. And my battery is brand new, only ran it for about a week. I am so confused. Any ideas, i need help!!!!
    Justin
    Quote Originally Posted by fordandmopar21 View Post
    That pretty well points to the alternator.
    Walking on the wild side! Shadowstealth's Avatar
    Jul 2008
    south park
    624
    i honestly would think its the alternator...what do you have to loose... get a new one... and then put it on... if it doesnt fix the problem clean it up and take it back... but i couldnt think of anything else... i know you said you tested it.. but ... i dunno... im not ase certified lol
    Aug 2008
    226
    I tested it at 2 different advances and it was normal voltage, i know what your saying though. It sounds EXACTLY like an alternator problem lol i guess i could go get one and see if it solves the problem.
    Justin
    Before you spend any money on it............
    What is the wiring like? There are fusible links in the charge wires on those cars. If i'm remebering correctly what car you have, when I looked at it, the wiring was a mess.
    If I was going to put money into an alternator, I would move to a 95 or 130 amp 3G. That conversion eliminates the voltage regulator, and runs a charge wire to the battery (solenoid, but same thing).
    Also, Frank should have an alternator he got from my Capri. We KNOW that is a good one that you could use to test.
    Aug 2008
    226
    Yes the wiring is fried on most of the car but the connecting part where it meets the alternator is good and metal is touching. Im pretty sure its not the wiring because i drove this car for about a month with no problems. I would like to convert to a 130 amp though, i have an e-fan and it would just be a lot better.
    Justin
    LowHill
    2,679
    I have had a fuse link bad going to alt wiring. sheck before and after fuse link for power.
    This is what I meant by that. Alternator will test good, but an open fuse link wont let it go anywhere.
    Aug 2008
    226
    I understand now. Ill check that out tomorow when theres daylight. Thanks guys!
    Justin
    2,483
    If you pulled the alt off and it checks out ok, reinstall it, charge the battery, fire the car up. Check the voltage across the + and - posts. If it reads zero, its gotta be wiring. I upgraded my alt to a 130, can't remember what the stockers put out at idle 12 amp?
    Aug 2008
    226
    I got it fixed, i feel like a complete idiot. It was a bad battery. Went to advance, got it exchanged and was good as new lol im glad thats all it was though.
    Justin
    Member loutheplumbr's Avatar
    Mc Donald PA
    80
    yep i've had several newer batteries have the posts burn off internaly and will show voltage but not pass any amperage through them
    1985 Mercury Capri
    2.3 Turbo T-5
    1988 Ford Thunderbird Turbocoupe losing its powertrain
    1993 lx vert getting re-powered
    1959 Ford 871 undergoing operational restoration
    2011 Dodge Ram 2500 HD Cummins
    1984 Ford E350 Tow Vehicle Project 7.5L
    Aug 2008
    226
    Well i thought i fixed the problem but its back. I drove the car for a good 2 days and instead of slowly loosing power it just shut off out of the blue and did the same thing as before. Im thinking its wiring. I have no clue at this point though. Any help again?
    Justin
    Charge?
    Simple fix would be a ROADFLARE But seriously check those fuse links
    JUNK IT!
    Aug 2008
    226
    Where are they? I was looking for them and i dont know too much about these cars yet.
    Justin
    link
    Check around the solinoid, or if you want, i can take a peek for ya and see whats up with it
    JUNK IT!
    LowHill
    2,679
    Did you ever change the wiring in that car? If not check around the solnoid because I think thats were you may find your problem
    Aug 2008
    226
    I did not change the wiring. The wires around the solenoid are a little burnt just like everything else but they seem ok, metal is touching metal so there is a decent connection between them.
    Do you know if that wiring harness on the t-bird at loskos will fit my car because im trying to find a complete engine harness?
    Justin
  1. ISO -- 2.3T charge pipe
    By blizzard in forum Ford Parts
    Last Post: 01-06-2013, 09:21 PM
  2. air-water charge cooler parts
    Last Post: 12-07-2009, 10:29 PM
  3. Looking for foxbody battery hold down
    By RUSH2112 in forum Ford Parts
    Last Post: 06-02-2009, 01:47 PM
  4. Steeda charge motion control delete plates
    By orange 500 in forum Ford Vehicles
    Last Post: 01-28-2009, 09:07 PM
  5. Help With Charge Problem??
    Last Post: 09-03-2007, 08:36 PM
