Results 1 to 9 of 9
Thread: 347 install update
    Senior Member TJH64's Avatar
    Delmont PA
    320
    347 install update
    Well, I haven't worked on or seen my car since last October, but the past couple weekends we started working on it again. I just want to get this thing done already and enjoy it!! You can see in the pictures, I still have minor odds and ends to complete, hoses, clamps, plug wires, breathers and oil fill tube, etc...
    This weekend we will be under the car installing the new prochamber, get the driveshaft in and install the new 255lph fuel pump.
    Looks good,
    you should really considering doing the Foxbody TB setup swap.. Will make the engine bay look alot cleaner and gives alil better throttle response
    978
    That intake is gonna choke it down.
    Uniontown
    1,792
    Hmm, save up and get a Victor intake :)
    Got Smoke?
    I vote a holley systemax 2
    Looks good TJ!
    I agree on the fox- style setup, you can pick the parts up super cheap.
    Keep us updated on everything!
    Delmont PA
    320
    I agree if this was a max effort, high winding engine, but it wasn't built for that purpose.
    Every part that is on or in this engine was chosen to work together, and the cam ground to make it all work. This was built for the street, with an occasional trip to the strip
    Delmont PA
    320
    Looks good TJ!
    Thanks Rob!
    I agree on the fox tb, but what would look even better is a Parker Funnel Web with a big Holley on top I'm old school, I like carbs.
    State College, PA
    3,552
    its so beautiful...hahah
    lookin good nice and clean
    2013 Mustang GT
    1999 Contour SVT
  1. Finished with the 347 stoker install! 90 fox
    By OctaneGraphix in forum Fox-SN95
    Last Post: 08-21-2012, 07:33 AM
  2. My Update - and some pics
    By no1fordgirl in forum The Bar
    Last Post: 05-24-2011, 10:36 AM
  3. Update
    Last Post: 03-12-2009, 08:51 PM
  4. Some progress pics of my 347 install
    By TJH64 in forum Fox-SN95
    Last Post: 09-19-2008, 08:04 PM
  5. Its Done, New Combo Update
    By Rio94gt in forum Fox-SN95
    Last Post: 04-18-2008, 12:13 PM
