Results 1 to 15 of 15
Thread: t-trim/mex block/tfs/pms/efi conversion/holley sys.. etc
    NEWB
    altoona,p.a
    299
    72 standard bore (never touched) MEXICAN 302 block..450.00
    trickflow twisted wedge heads --- 1000.00 for all
    cut for o rings, look great, 10,000 miles (est)
    track heat .600 spring upgrade
    comes with hardened pushrods and comp pro mag rockers 7/16
    polished vortech (race m) T-trim 87-93 --- 2500.00
    complete 100% brackets,nuts,bolts,washers,hoses,lines,couplers,c lamps etc..
    has anderson ford motorsport mondo bypass kit with it
    vortech polished mondo bypass valve
    2.95 upper pulley
    stock 30k miles shortblock (no cam) double roller cloyes chain,arp head bolts, fms lifters,dog bones,retainer,oil pump,oil pan,pick up etc --250.00
    afm series 3 pms w/ map sensor (87-93)---625.00
    75mm prom bullet meter for 24's ---100.00
    80mm s/c pro m for 42's (filter mounts to it) ---150.00
    24lb ford motorsport injectors---125.00
    aftermarket blue fuel rails with fittings/cross fuel line (cartech) ---75.00
    1993 complete efi harness/inj harness/mass harness/ecu/sensors etc..
    this is perfect for a efi conversion ---250.00
    holley systemax2 intake w/ 1inch spacer and all hardware...450.00
    this is 3 months old from summit..
    please email or call 814-207-3299 i dont check pms often,
    ruthlessgsx@aol.com i can get pics as requested...
    more stuff to come..thanks
    "biggb"
    NEWB
    altoona,p.a
    299
    ttt
    mexican block is a 71 not a 72 thanks
    "biggb"
    Charleston, WV
    46
    Is the Systemax intake for a 302 or 351?
    Member badstanglx's Avatar
    altoona
    676
    its for a 302
    i b where im at
    674
    r the trick flow heads complete . i have a stock block . wonder how these will make my car run ..
    NEWB
    altoona,p.a
    299
    i just re did my add a few posts up, forgot i had this one going, the holley is gone
    tfs heads are complete ready to bolt on and go, they came off a stock block car, ran 12.4@111 on street tires
    "biggb"
    NEWB
    altoona,p.a
    299
    71 standard bore (never touched) MEXICAN 302 block..400.00 +shipping
    trickflow twisted wedge heads --- 800.00 shipped
    comes with crane 6.750hardened pushrods
    polished vortech (race m) T-trim 87-93 --- 2400.00 shipped
    complete 100% brackets,nuts,bolts,washers,hoses,lines,couplers,c lamps anderson ford motorsport mondo bypass kit
    2.95 upper pulley
    7inch crank
    upr smog elim
    80mm s/c pro m for 42's (filter mounts to it) ---150.00 shipped
    24lb ford motorsport injectors---125.00 shipped
    updated adds and new prices, also the mex block is a 71 not a 72 thanks
    "biggb"
    Quote Originally Posted by nastynotchturbo View Post
    sorry to hijack your thread, but was that ET/MPH with the systemax? what cam? i'm putting together a stock shortblock combo and just curious to see what it'll run.
    2001 Mustang GT: JLT CAI, Pypes o/r-x, Magnapack catback.
    1987 Mustang GT: H/C/I, suspension, interior, you name it, 314whp and 307wtq and climbing at the fuel cut sold
    1992 Mustang LX: cam, exhaust and CAI. 227whp and 295wtq, sold.
    1970 Nova SS: built 350 on the bottle. 10.6 at 125. sold
    UnitedStangs.com--R.I. Chapter President.
    NEWB
    altoona,p.a
    299
    Quote Originally Posted by Green92LX View Post
    3.55's, f cam , perf rpm , these heads ..12.4@111
    holley intake, stage 1 cam , these heads .. unkown, but it did FEEL faster.. the heads work very well, if you do a few simple things to them
    "biggb"
    thanks bud. i have 3.55's and i'll have TFS track heats, TFS stage 1 cam and a systemax in a week or 2. nice to know it'll make good power.
    NEWB
    altoona,p.a
    299
    every car is different, it should do ok, i had just enough work in these heads to get the job done.. now with a good sticky tire and a 4.10 11's would have been easy for it
    "biggb"
    i actually just decided to go with some 4.10's. what's different that would make more power over the out of the box TW's? seems like the only difference is the springs, which the TFS track heat heads already have.
    NEWB
    altoona,p.a
    299
    they were sand rolled and some lite bowl work, nothing crazy.. the car worked well, attention to detail goes a long way...
    "biggb"
    ooh, i gotcha. well i'll be happy with anywhere in the 12's.
    thanks for the info bud.
    NEWB
    altoona,p.a
    299
    bump
    "biggb"
  1. holley sys intake, shortblock, cam etc
    Last Post: 08-10-2013, 01:07 PM
  2. Replies: 1
    Last Post: 05-31-2009, 02:57 PM
  3. mex 302 block, tfs r box, injectors, gears etc
    Last Post: 04-13-2009, 06:35 PM
  4. mex block, t trim, stock s.b, tfs heads etc
    Last Post: 03-23-2009, 04:21 AM
