Results 1 to 9 of 9
Thread: Carb spacer
    2,483
    Carb spacer
    How bad does adding a carb spacer affect air/fuel. More so, if I added a spacer to a car should it be retuned? Or is it not affecting the air/fuel enough to warrant a rejet/retune? I was giving thought to purchasing a tapered 4 hole for my setup. Have read nothing but good things about this style of spacer. The overall consensus being that it creates more airflow through the carb, adding to atomization of fuel, which I believe I need. Although I may have answered my own question, still looking for feedback.
    the tapered spacers affect the fuel signal from the carb alot, depending on the spacer. Keep in mind the hood clearance as well.
    2,483
    Hood clearance is the main reason I haven't bought one yet. Thats why I was hoping I could get away without a retune. Got one for sale? Preferably phelonic?
    i have a phelonic 4 hole(they increase slow air flow velocity), but thats not what you want on a big rpm screamer!! you want either a open to increase plenum volume (which raises power band) or a tapered which helps to staighten airflow and increase fuel signal from the carb with high air flow velocity..
    2,483
    I've read that the 4 hole tapered spacer gives the best of both, power across the whole band. The larger I move in powervalves I was concerned with losing too much lowend. Figuring the above spacer would solve both. Worried that an open spacer would only enhance the lacking of a lowend. Although i'm only coughing up what i've read and no real world experience with these.
    lets dyno it with and without!!
    2,483
    I don't have one yet.
    C'mon B-Dubs, 4.10's and 4 inches of stroke, you can stand a trade off anyday with those attributes.
    We have the same hood. A 6-71 huffer would fit with no clearance issues!!!! HAHAHAHAHHA
  1. 99-04 v6 intake spacer
    By punkbomb138 in forum Ford Parts
    Last Post: 07-19-2011, 09:33 PM
  2. steeda driveshaft spacer
    By gtboost02 in forum Ford Vehicles
    Last Post: 03-30-2011, 05:46 PM
  3. 75 mm TB spacer
    By coupeguy_black in forum Ford Vehicles
    Last Post: 03-03-2009, 08:16 PM
  4. 1in Spacer
    Last Post: 04-20-2008, 01:30 PM
  5. Wheel spacer help!!!
    By Rio94gt in forum General Tech
    Last Post: 05-27-2007, 08:24 PM
