Rush,
Your tranny should be fine!
If the motor you are putting together doesn't make 350 rear wheel I would be pretty upset.
Later
102K ON my stock t-5,,, thats seen a blower for about 3k that was around 400hp at the motor and the current setup now that is around 340 at the motor and it still shifts perfect, no grinds, etc and thats w/ drag radials and a very rare trip to the track
2014 RAM QUAD CAB 8SPD
Here ya go. http://store.summitracing.com/partde...5&autoview=sku
I wouldnt buy a crate but here ya go.
I think your right. I price out all the parts and aside from the machine work, it is $3000 for a stroker build.
But the $4000 crate motor doesnt include the TB or the induction.
So $4000+ for a crate motor that puts out 345hp (which is probably crank)
or $3000+ for a 347 stroker motor that puts out 350RWHP, plus I get the satsfaction of seeing/helping to build the motor.![]()
it would take one hell of a combo to get near 400rwhp out of a 347....those are 351 stoked #'s.... bad88ttop has a bad 347 setup w/ a systemax intake and fox lake ported TW heads... i'd shoot for 350 at the wheels and you will be happy with the results esp. for a street car
Well I'll list what I want to get and you tell me what you think. Also, If I have the heads ported a little bit, would that help?
Exhaust - will reuse current setup. BBK longtube ceramics, O/R h-pipe, flowmaster catback
Cam - not sure yet. might go with the XE266 something or other, or possibly a custom grind. I want to have a heavy lope with an aggresive idle
Rockers - 1.71 roller rockers
Intake - probably not the best choice, but a polished ford racing 'cobra' intake (possibly with a port job). I know their are much better intakes out their, but I want to slowly chrome out the engine.
TB - not really sure about a model, but at least 65mm or higher. Also want to get a 70mm or higher MAF calibrated w/ 30lb injectors
460FWHP/347c.i.d.=1.325 FWHP per c.i.d. 460FWHP/15% loss through a T-5 (estimated loss) = 400RWHP.
1.325 FWHP per c.i.d. is an "achievable" value for a "street engine". With a well thought out "combo" (I'm not getting into a pissing match over cylinder head choices here) the 347 can have good street manners and produce the numbers he expects on pump gas.
The exhaust: What size are the primary tubes on the long tubes?
The cam: custom is always a great way to match the combo. The xe266 is too small for a 347 application. That is a 302 part for sure.
The rockers: 1.6 ratio "should" suffice "if" the cam is selected correctly.
The intake: The cobra intake will produce an abundant amount of low and mid range power BUT that intake may become the limitation in your quest for 400 RWHP
The T.B.: 75mm T.B. and a M.A.F. equal to that size or larger.
Not sure about being able to port the 185's. I am not aware if there is any material left to increase port volume. I do not think there is a "best" head. It's all about the combination. I know it sound cliche, but it is the truth. I have seen many TFS Twisted Wedge combo's that produce horrible numbers(if that is what appeals to you) and then again I have seen AFR headed small blocks that were lethargic as well.
Being able to appease a budget and being satisfied with the results sometimes is never realized. Getting caught up in numbers can take the fun out of it. My best advice to you would be to do some research on the corral(did I just say corral). There are a couple of 347's that produce 400 @ the tires. You may be able to base your combo from what somebody has already researched and proven.
Hardcore50.com is also a great place to lurk around and take in what is said. This is a premier site that offers zero tolerance for ignorance. I have learned quite a bit from the people over there!
Thanks for the tips. Your right. If I am only good at one thing, it is research and I do it very well. I can try to find someone who has what I 'want' and see what they put out, then find someone who 'puts out' what I want and see what they got. I am in no hurry, just gathering data for now.
Something that may interest you.
http://airflowresearch.com/articles/article110/A-P1.htm
