Edelbrock Performer Heads, BBK Ceramic Long Tube Headers, BBK O/R H-Pipe, BBK Cold Air Intake, BBK Strut Tower Brace, Flowmaster American Thunder Cat-Back, FRPP King Cobra Clutch, FRPP 3.73 Gears, FRPP Chrome Cobra Upper/Lower Intake, FRPP Chrome Polished Valve Covers, Chrome Alternator, Ford B303 Cam, Holley Fuel Pressure Regulator, 70mm Edelbrock TB, 75mm Pro-M MAF, #24 Ford Injectors, Crane 1.7 Rockers
i know 400rwhp is doable w/ a good working 347 combo... but would take alot more $ and i doubt it would be very streetable as he wants his to be.... Do you want to lose your a/c? smog? even a heavily worked cobra intake will be the bottleneck but it would still put a smile on your face and would be interesting on a 347.....
i cant see hitting 400rwhp as a goal w/o a custom solid roller cam, different intake and maybe even the 205 heads or a different head all together as well as getting rid of the a/c, smog, etc...... either way, do your research and talk to some of the cam gurus and they might be able to point you in the way that best fits your goals...
2014 RAM QUAD CAB 8SPD
Here is a streetable 347 combo that makes 460 RWHP. And here is the phone number for anybody in dis-belief. 330-634-2155 Ask for Brian Tooley proprietor of Total Engine Airflow.
347 11.0:1 compression
TFS TW 205cc CNC'D
Off the shelf TFS hydrualic roller cam NON-custom
TFS R-series lower with TFS R box upper
90mm T.B.
1 3/4" headers
See I just had to put that TFS plug in there
I think its more than doable, I will be tayloring my engine around this one from Corral!!
"83 conv,stock 88 bottom end with dremeled pistons,vict jr heads,vict jr intake,750 dp,anderson n91,tremac3550,spec stage2,4.56 gears,spool,superior axles,hal k member,90/10s,50/50s,best et 11.22 at 122.00 388 rwhp 331fpot "
Pretty good, I have my Cobra upper out being ported as we speak, should have it back in another week or so. I need to get this K-member installed along w/ the Moroso spring I got from you & the Lakewood 90-10's I got from Tom. Then im gonna have Tim Rodehaever weld in my upper & lower torque boc reinforcements. Couple other little thing here & there, but thats the most of it. How bout you, are you leaning any certain way for a new combo or are you going to try & get a little more out of your current combo?
You just might have a 10.5 in that badboy!!
That sounds like what you'll need to get into the 1.5 60' realm. I'd like to pull out a little more weight for this upcoming season. I will most likely keep the combo the same for the most part, although, it's those little tweaks that I'll be experimenting with for '07. I also want to get that thing dynoed in the current configuration. Kooks headers may be a welcome addition as well. A tune would be beneficial too, I think
Put this one in.
http://steelcitystangs.com/forums/sh...4877#post14877
Thanks for the link, but I don't wanna convert to a 351
